Road cassette on MTB hub
_freak_
Yes, provided the number of gears match
Not necessarily, my 10speed cassette fitted on a 8speed freehub and vice versa.
I will have a look this afternoon to see if the same is true for 9spd freehubs
Yes, that is true. I was referring to the use of an MTB derailleur.
Provided it's a Shimano/SRAM cassette it will fit an MTB freehub
Shimano cassettes since 8 Speed are compatible with 8, 9, 10 and 11s MTB.
Only the road 11s cassette is different.
The old 7 speed cassette I doubt is in production anylonger..
yes, i understood it as:
as long as its a 10 spd cassette and a 10 spd derailer, it should be fine??
in that case, thanks all, this will work fine for my plans then...
Im running 2x10, close enough to granny, but not granny...
Ja, but I'm thinking if you want the extra speed, add a bigger blade in front. Then you have the speed as well as the granny. Although that will be far more expensive because a new crank is then required.
