Rapide - SRAM 11 Speed Upgrade Kit
NotSoBigBen
So basically if I have x9 shifter and clutch RD, then the RD once shifter is converted, will be able to adapt to 11 speed?
So ill only need a cassette and chain?
  • Replies 148
I'm kinda sad I went 11 instead of 1x10...The cassett's and chains are a SH1TLOAD more expensive...Like double the price of 10spd XT cassette :P
This is not necessary as the plastic part has lugs which fit quite snugly into the cutouts of the gear selector.
Yes I am aware of that hence i said "can simply use". It's not prescriptive.
I have worked on these shifters and some of the ratchet wheels and plactic retainer have a more lose fit. So if its one of those then a self taper makes life a bit less irritating :)
