DIY bicycle repair stand- looking for a clamp
Spock
Hi
I plan on building my own repair stand, but need to find a solution for the clamp. I notice one can buy clamps from cycle shops, mainly online overseas shops, but these are too expensive. Any suggestions to solve this problem? What can i use?
Thanks!
Fabricate a clamp using 2mm plate, rubber padding and threaded bar an wing nuts. Just make sure it doesn't damage the frame when you clamp it.
It's referred to a "reverse engineering" where I come from.
Good luck.
Guest notmyname
At five hunt rather just buy the tork craft one. I've seen them for little over four.
I have the Craft Tork one from CWC. Worth every cent. Fold up nicely when not in use, not taking much space. It is so cheap I will not go through the hassle of building one self that can end up more expensive / damage your bike...
