Best budget road wheel for 5k or less.
Brickleberry
Looking for opinions on the best budget wheelset avaliable at 5k or less. Looking for strong and durable, for a 88kg rider. Sealed bearings are preferential, and the budget can't get bigger so hand builts or higher level wheels are not an option.
Been looking at those , probably my top choice right now
Speak to Jonathan. As bikebloke mentioned, Jonathan will give you honest business and he knows Campagnolo very well
I have got a set of 30mm profile , Token C30a wheels available for R4000. It is currently for R4800 in the classifieds. It weighs 1.54kg with skewers. It is in excellent  condition. You can give Francois at Manic Cycles Worcester a call  If you are interested. I bought  it there and it is there now. Those wheels are going for almost R10000 now if you buy them  new.
American Classic Victory 30's. On sale at Evo Bikes for less than 5K. AMC know aluminium very well and these are 118kg rider limit and nice and wide internally (18.2mm) so you get a better tyre profile. Plus AMC hubs are all time in the fast rolling stakes. 1592gm a pair, no weird spokes if you need to source them, out of the box set up as tubeless with sealed inners but can run with happily with inner tubes. Come supplied with tubeless valves as well.
http://www.evobikes.co.za/wheels/wheelsets-road/american-classic-victory-30-tubeless-clincher-wheelset.html
That weight scares me a lot. At 88kgs I'm nervous to go under 1500g.
Fair comment - I'm normally between 85 and 90kg's and haven't had a problem myself. You would be covered by the warranty though if that helps your confidence.
