Very good deal on that SRAM groupo IMO, but if that's a stretch too far, Hope V-Twin system around R4500 plus shipping, and TRP Shifter/Caliper around R1700 plus shipping each from CRC.
http://www.chainreactioncycles.com/za/en/hope-v-twin-road-cx-brake-system-e4-calipers/rp-prod130427
http://www.chainreactioncycles.com/za/en/trp-hylex-hydraulic-disc-brake/rp-prod150527
Just depends how disappointed you are with your bikes braking performance I guess :)
Each time I do a search, Jagwire pops up. Wiggle and CRC are good bet. Locally? Who knows?
I had Jagwire on my Niner, which was crappy from day one.  Changed it to Shimano, I think the MX range, and they perform much better, especially the on the back brake.
I am satisfied with jagwire compressionless housing with my Veloce shifters and 160mm discs front and rear. Haven't ridden hydraulic, so cannot compare
  • 3 years later...
Question to those who might have tried these products, was there any performance issues, and is the "Link" type much better than the regular type?: To be used with TRP Spyre Mechanical Disc brakes
Jagwire Pro Brake Cable Kit
Vs
Jagwire Road Elite Link Brake set
They are both stated as "Compressionless"
Edited by EddieV
much of a muchness.
The MTB pro kit uses metal cable end caps and a broad flat wound wire to create a compression-less housing.
The Links kit uses hundreds of alloy "links" in a ball and socket arrangement with a friction-less Teflon inner to create a compression-less housing. Looks more bling and might not fit through the frame cable guides.
