Fox Float CTD has no compression dampening.
Alastair_S1D
Basically what the title states.
I have a 2013 Fox Float F32 EVOLUTION CTD.
I recently had a problem with the rebound but my shop managed to fix it.
Now my CTD dampener isn't working and my LBS has tried everything they can think of. There is absolutely no difference between climb, trail or descend modes. Any one have this issue before. Any ideas on how to fix it or will I be sending my fork to the fork doctor?
Have exactly the same problem, the shock will have to be sent to omnico. Looking at about R1200.00
Do yourself the best favour and send the Shock to www.robbiesbicycleconcept.co.za and he will not only repair the issue, he can also tune the shock for your bike, your weight and riding style.  He is authorized to do so, and has more aftermarket kits to upgrade the shock.  He does Push Industries kits which are the finest in aftermarket pistons and shims to achieve your ride feel.  A far better ride starts here.  I have had both my fork and rear shock done with him, and he has nailed my ride feel.  Omnico CANNOT rival this.  They can service and replace parts but not get the ride feel.
The rebound seal has blown, and you'll need to replace the damper. Basically the best thing you can do for that fork, because the current damper is possibly the worst thing that Fox has ever made.
It's not going to be a cheap exercise, but unfortunately it's the only way.
The GRIP damper is also available, which is the direct replacement for the EVO CTD. Comes in a bit cheaper and no reliability issues so far.
Now you guys got me wondering if I shouldnt just save up for a nice new F32 step cast. :/
It doesn't rain. It pours.
Trying to sort out a new road bike after a incident with a car.
And now my MTB has decided it wants to start falling apart. Fork and my XT785 levers are giving me issues.
What is the absolute cheapest solution to see me through?
Grip damper and cleaning the pistons on the levers.
Search xt brake lever work arounf
