Rouxenator Posted September 8, 2017 Posted September 8, 2017 After having done 10,000km on Chaoyang and before that Maxxis I decided to try out a new cheapie brand from China and settled on the Innova-Pro Transformers. Now normally when you want something fancy you get it from a Boutique. Think of fine clothing, confectionery, furniture and so on. If it is fancy stuff it will most likely be "boutique" stuff. So based on that these must be really fancy because it is the first "boutique tyre" I have ever had in my life Sew fahunseh ! Fitting them on my Giant P-XC2 rims was easy enough, I added 100ml Rhino sealant in each wheel and pumped it 2.5 bar and it seems to hold that without any leaks. They do seem rather skinny compared to my old 29x2.2 Chaoyangs. Tomorrow I will test them out on Piket-bo-berg, a route I am not familiar with on tyres I am not familiar with. Let's see how it goes.
Hairy Posted September 8, 2017 Posted September 8, 2017 After having done 10,000km on Chaoyang and before that Maxxis I decided to try out a new cheapie brand from China and settled on the Innova-Pro Transformers. Now normally when you want something fancy you get it from a Boutique. Think of fine clothing, confectionery, furniture and so on. If it is fancy stuff it will most likely be "boutique" stuff. So based on that these must be really fancy because it is the first "boutique tyre" I have ever had in my life IMG_20170907_155455240_s.jpg Sew fahunseh ! IMG_20170907_155508637_s.jpg Fitting them on my Giant P-XC2 rims was easy enough, I added 100ml Rhino sealant in each wheel and pumped it 2.5 bar and it seems to hold that without any leaks. They do seem rather skinny compared to my old 29x2.2 Chaoyangs. IMG_20170907_190748607_HDR_s.jpg IMG_20170907_190806781_s.jpg Tomorrow I will test them out on Piket-bo-berg, a route I am not familiar with on tyres I am not familiar with. Let's see how it goes. hey ... those will provide a gazillion times more grip that your previous slicks!
Rouxenator Posted September 8, 2017 Author Posted September 8, 2017 They sure will, I put the old Chaoyangs through the dishwasher so they are nice and clean now. Maybe I should send them back to Chaoyang so they can have a look at 10,000km tyres If these ones copy more than just the thread pattern from Schwalbe then they will of a rather soft compound and not last very long.
Kalahari Vegmot Posted September 8, 2017 Posted September 8, 2017 Price? No reason for china tyres if the not cheap...
Rouxenator Posted September 8, 2017 Author Posted September 8, 2017 R380 each at BuyCycle. I had that much in credit with them so I paid for one and got two. they also have a slightly cheaper 120TPI version. https://www.buycycle.co.za/mountain-bike/innova-pro-transformer-race-29x2.10-tcs-60-tpi-tyre/
Belgarath Posted September 8, 2017 Posted September 8, 2017 From Buycycle's site... "HADAR is the designated tires for the 48HR endurance Race of Taiwan" Dunno if they actually know what loose, sharp rocks are. Although, neither do you Capies... :ph34r:
Hairy Posted September 8, 2017 Posted September 8, 2017 From Buycycle's site... "HADAR is the designated tires for the 48HR endurance Race of Taiwan" Dunno if they actually know what loose, sharp rocks are. Although, neither do you Capies... :ph34r: are those the rocks you guys have on those long straight district roads you "mtb" on
Flippa Posted September 9, 2017 Posted September 9, 2017 FYI, Innova make tyres for a host of other manufacturers, including Surly. My set of Innova made Surly Knards have lasted very well on Gauteng's rocky trails at 0.6 bar. Sent from my C6603 using Tapatalk
Rouxenator Posted September 11, 2017 Author Posted September 11, 2017 I was impressed with the Transformers on Saturday. They do seem more like 29x2.0 to me, very round and narrow but that could just be because I am used to worn out 2.2 tyres. At 2.5 bar they offered good grip but on loose section they do tend to sink in a bit. At the price they are hard to fault.
Rouxenator Posted November 27, 2017 Author Posted November 27, 2017 Just over 3 months and just over 2200km and I'm throwing in the towel on these. They started out great but 3 days after my last post they dropped in pressure and had "bumps" where the bead was not seated, pumping it all the way up to 4.5 bar, leaving it to settle and then dropping back to 2.5 bar fixed it. But alas, the punctures. Yes, these tyres only seem to seal if the pressure inside the tyre is 1 bar. Anything above it and will start blowing out of puncture holes until either you run out of sealant or the pressure gets to 1 bar. Those who know me will know I push tyres beyond their limit as long as they play along. These ones do not. Perhaps the tread pattern is not all they copied from Schwalbe and this is my first encounter with soft compound tyres? Anyway, this is the rear one and it is in the bin. Back to Chaoyang Hornet at the back, I'll see how the front Innova holds up over the next few days.
Breezer Posted November 27, 2017 Posted November 27, 2017 Hy is in elk geval in sy moer gery, daai rubber is al te dun om te seel.
Rouxenator Posted November 27, 2017 Author Posted November 27, 2017 Ek het al baie beter gehad met Chaoyang en Maxxis, al het hulle erger gelyk. Die oukies is te sag.
Breezer Posted November 27, 2017 Posted November 27, 2017 Ja, 2200km is maar min om so min loopvlak oor te he.
