Zwift - Zwift or Garming uploads to Connect
JTK
So I have been Zwifting a little. I use both my fenix and Zwift to track the activity. I connect zwift to garmin connect to upload. Why do I do both? Because the swift activity tracking has other date like elevation tracking etc which the garmin does not track indoors. And Garming has some fitness lated activity it tracks that the zwift tracket does not. However I now always have two activities uploaded. I am also still not sure if it is doubling up on certain stats?  What do you guys do?
Unless you are monitoring TSS and using other software/platforms to monitor fitness, fatigue and form then having 2 activities on garmin shouldn't be an issue.
Of course all of the reports in garmin connect will be of minimal use as you are doubling up everything for IDT and i presume only uploading garmin when out riding.
If you need the points for vitality, then you will need the garmin uploads as you get zero points for any zwift upload.
ah yes! but didn't you know? IDT sessions count double because there's no coasting downhills!  :clap:  :clap:  :clap:
