Rock Shock oozing grease on first ride
BikeOverIt
Fairly normal as far as I know. Just some assembly grease popping out. If there was a problem you would see a lot more coming out.
You should see little bit of greasy/oily stuff after each ride - just wipe it clean.
I'm sure some suspension gurus will confirm shortly...
I thought sram butter is red
Red rubber grease is red. SRAM butter (AKA Slik Honey AKA Slickoleum) is yellowish. RS seal grease, which is what should be in there, is light green.
