Strange sound from cluster when freewheeling
Shaunpr
Hi, when I am on a fast down hill and my racing bike is maxed in terms of speed and I freewheel there is a strange noise emanating from the cluster, then if I continue to pedal then the noise dies. This only happens at higher speeds. Could the bearings be finished? Ho do I fix this?
That is a regular issue with Mavic Freehub. Caused by the plastic / ceramic insert A small amount of oils or grease will stop the noise for a while but eventually you will have to replace
Not what I was hoping to hear. Thanks none the less.
Don't ride it like this, get it fixed. I wrecked my frame with a mavic hub failure, turned out to be expensive.
Thanks for this :thumbup:
Recommendation: dont use Mavic hubs. You can do better for less money: Shimano, Hope, DT, etc
Listen to this guy. He's clearly had experience.
Thanks, will remember for the future
