Shimano XTR 1 x12
Piet
If you want to run the shimano XTR cassette, you will need to change the free body on your hub. Only a few brands have this free body so it depends what hub you currently are using. If it’s compatible, you’ll need to get a new freehub, if it’s not, you’ll have to get a new compatible hub.
You need a new freehub, 12 speed xtr can only fit on microspline freehub and they only come on Shimano's new xtr hubs or limited Dt hubs
You can always get the 12 speed XTR derailleur, shifter and chain. Then match it with a Sun Race 11t - 50t cassette. The cassette will fit your current freehub, and has almost the same range. The Sun Race cassettes are also very durable, just a little bit heavier than the XTR cassette, but way cheaper.
Remember to double check if you'll need a new hanger for the derailleur to be able to reach the 50t on the cassette.
  • 1 month later...
