Garmin Edge 1030 & Bluetooth Smart Trainer
MudLark
Hi guys, is there any way to connect a Garmin Edge 1030 and a bluetooth trainer? It strikes me as a bit bizarre that the 1030 has both bluetooth and ANT+ built into it but only offers the option of connecting an ANT+ trainer and not a bluetooth trainer. Is there a widget or a workaround?
1030 can connect via bloutooth to a trainer.  Have done it with a Tacx
Okay... thank you. Would appreciate it if you could explain how... because when I try to connect a Bluetooth trainer it only offers the option of ANT+ and the manual only speaks about ANT+ - no Bluetooth (see the link below). Miskien is ek maar 'n bietjie dom...
https://www8.garmin.com/manuals/webhelp/edge1030/EN-US/GUID-FFCC4A60-77F0-4DD8-9302-F78A50FBB0BE.html
Okay. But when I run Rouvy on my iPad with blutetooth it controls all aspects of the trainer. So I doubt that's a limitation.
I think the limitation is there's only two way connection between to devices while ANT+ allows multiple connections
Not sure. Polar H10 Bluetooth can connect to at least two devics simultaneously. But here again, I'm only trying to connect a single device - a Bluetooth trainer. IMHO, Garmin's dropped the ball on this one.
  • 2 months later...
What was the outcome? How many times have you had the blue halo problem?
The unit was replaced. The previous unit was the first blue halo problem. One before that the screen just died. Apparently blue halo is common and known problem.
