Home Alarm system
The Ouzo
I've got an old system in my place, DCS I think it is. 6 zone system with no room for expansion.
I've always wanted to upgrade but today has prompted me to look into the costs and get some quotes etc.
So what I need
minimum 6 passives. If 3 of those are linked into 1 zone its ok.
3 door sensors
2 garage door sensors (can also be linked to 1 zone)
3 maybe 4 outdoor sensors
fixed panic buttons (i.e. buttons permanently mounted)
I currently have remote panic buttons but I'm not even sure where they are so maybe not that important
ability to link to security company
Nice to have in order of importance
Remote activation - I'm talking physical remote
Internet connectivity - monitor/activate etc. with an app
future expansion
So wise ones, point me in the right direction. Budget is non existent for this, so dont go spec me a Pinarello as I can probably only afford a Ralliegh
  • Replies 34
Check with communica, they sell all the alarm stuff as well. Then you can either DIY or get someone
Although I can DIY I just dont have the time, so would prefer someone to install for me
I just had my new alarm installed yesterday. I chose a panel that can be partitioned into 8 zones expandable to 64 zones(That doesn't mean much to me but the guy says it's a lot). I got two 4 button remotes. Currently 1 button is the panic and the other is arm/disarm. I got beams around my garden. I only have 3 beams for now as my budget was R15k initially and I can add on at any time. The security company(SOS 24/7) installed it and they do the monitoring for an additional monthly fee.
So in the next few months I will add a few more beams outside an then some door sensors. I don't think I will bother with passives as all my windows will be covered by the outside beams and all doors will have sensors. Once they pass that then what good will the passive be?
The Total installation cost me R15 402.61
DSC Alarm Panel R1805.50
DSC keypad R1098.25
12V battery R510.60
Transformer R325.45
Siren R67.85
Sherlo 4 button remotes(x2) R312.80
Sherlo 2 channel receiver R266.80
Cable 6 core R575.00
Takex 90deg 12M beam (x3) R5012.85
The rest was labour, link up and first months fee.
EDIT: labour was 7 hours R4427.50
DSC keypad R1098.25
12V battery R510.60
Transformer R325.45
Siren R67.85
thanks, this helps me alot.
No problem,
One of the quotes the same company gave me for another system was this:
OrC20Zone - Orisec 20 zone kit R 3,835.25
1x Panel
1x Keypad
1x transformer
1x battery
2x passives
2x fixed passives
2x door contacts
So this was a pre packed kit and not customisable at all, hence the reason I went with the other one. Labour was a little bit more for this one as well(8 hours)
If you have beams outside then I think you have to use remote buttons for when you drive in and out to arm disarm. Well that's what I have to do now. I arm the beams when I leave with my family inside the house.
You have options:
1 - set that outside beam to a delay zone, but make it audiable on the keypads - with dsc there are several variants you could try to see what works for you - including a delay on exit but instant on return
2 - arm the system to stay mode once you are outside of the property - assuming that your remote/receiver system is capable of this (it should be)
3 - stay as you are
I look after my own alarm configuration and install wise - started doing my own alarm because of no budget 25 years ago, and I given up on installers capabilities to read manuals and translate them into practice - doing the config with dsc is easy enough using either a full lcd keypad or connecting a cable to it and using their software.
You have options:
3 - stay as you are
This is good to know. Once I am a bit better with the basics then I will play around. One of the beams is a bit sensitive and it went off twice last night and luckily I was able to bypass just that beam but other than that I am not so clued up yet.
You can drop the sensitivity on the newer optrex passives - not sure if I have found your model - but... http://navi.optex.net/manual/50105/en/DNTXSYnwcvgaqt.html
and for the PIR - http://navi.optex.net/manual/50105/en/OKNRSYrgaqykex.html
Thanks Doc, This is good gen. I have informed the security company and they said they want to come set it but after sunset so I will take them up on that this time. As I was on a 15k budget this time I was only able to get 3 beams. BUT in November I will be adding the rest so I am sure there will be more settings to be changed so I will give it a go myself. Only thing I will have to do is call the control room and tell them not to come in all guns blazing for the next few min while I test the system.
Just make sure your installer gives you the installer code and the master user code - then you can diy it pretty easily - but without the installer code you have to set the panel back to defaults and repeat the install - which is more a pain than a problem - although the monitoring company would need to repeat their radio installation as well.
