Upgrading to 12-speed
nick_the_wheelbuilder
Thank you Nick
May be worth mentioning that many of the 11-speed options fit straight onto the older Shimano HG freebody.  Think the widest range being the 11-50 Sunrace cassette.  So not the max gear range as found in the 10-50 options, but a nice affordable option.
Nick what is your experience with the e13 9-50 setup ?  Is it as easy as replacing my GX cassette, maybe a slight adjustment of the B-screw and checking the limit settings ?  On the tar sections I often want just a bit more top end ....
Thank you Nick
I have no experience with the e*13 except that they seem pricey, but are really well made.
Thank you Nick
They are pretty well made, but pricey. Just a non-starter if you have Hope Pro 4 hubs as they need a little shim which turns fitting the cassette into a very fiddly, time consuming, and painful experience which results in a creaky cassette/free body interface.
