Hi all
Got a Suntour epicon from a friend and need a replacement axel
only problem is he used stock axle to try beat bearings out of his bmx :whistling:
15x100mm diameter axle is the stock ones length
https://cyclosport.co.za/index.php/buy-now/wheels/skewers-thru-axle/suntour-q15-axle-fka069-15mm
any alternatives ones that wont bankrupt me?
would consider making one but most aluminum stock/tubing is 16mm or 14mm :mellow:
if anyone could suggest a engineering firm in Capetown that could make one otherwise
Edited by Mongooser
Suntour axle i the only thing that will fit, but the one you've linked to is Boost. You need the standard one. Agents have stock, any Giant or Suntour dealer can order for you.
Found a piece of copper tube with a od-15mm and a 12mm id *perfect* 1k psi rating too. Then found a 12mm 135mm syntax axle and the nut for it to stick in the pipe as secondary security and the pinch mechanism.
It all fits perfeclty and snug, its way more rigid than that stock one
Took about 10 minutes to make and check clearance is in spec.
Hopefuly it wont kill me
Apologies for the potato photos
Edited by Mongooser
the only thing id maybe worry about with this admittedly epic hack, is the galvanic corrosion between the copper and alu/steel surfaces that are touching
Ill make sure to keep it greased and dry till I make one out aluminium. Thanks for the info! I forgot about that lol
Edited by Mongooser
