Hub conversion - through Axle to Quick Release
Need some information. Can you convert a Shimano FH-M678 MTB hub from through axle to quick release. What do I need to get that done.
My search on TheHub and Google does not give me enough info or a solution.
I'm not familiar with that hub but if it is a front hub and 15 x 100 (non boost) I can help you.  I had a "converter" machined for me but since sold the bike I used it on and hence don't use it anymore.
If you can collect (or pay for postnet) you can have it for free.
PM me if interested.
Edit:  Never mind I see its a rear hub, sorry.
Edited by Theog
Hi
I am busy with the same issue - converting an old Specialised rear hub to Qr - and have been reading and investigating - the more upmarket ones - will have their own converters - such a Lyne and stand etc. it depends on what the "endocarps" look like - if they can be removed and replaced with a QR version or you need to use a converter - the challenge with he converter is that they add width to the axle - 2mm flange each side to end cap so might not fit if not proprietary or you have to machine down the axle end caps to make it fit. am busy with my own conversion - have machined the new converter - but now need to take off the 2mm of each of the end caps - so a bit of a mission - but doable.  basically you need 155mm rod with a 5mm hole down the middle that comes in two bits - one for each side - or one long one to go all the way thru (most drill bits are  not that long so not that easy to machine
This:
https://www.aliexpress.com/item/1005001808560506.html?spm=a2g0o.productlist.0.0.69b53a52DMX40a&algo_pvid=4c914700-46d6-490f-9c0f-f7f4bd837217&algo_expid=4c914700-46d6-490f-9c0f-f7f4bd837217-14&btsid=0b0a556116092218967402413e6786&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Yip that is exactly what you need, you get both front & rear on that add, but look at the shipping cost ...  :wacko:
That's why I had a front one made for me locally.  If you can get the sizes, this might be a good option.
Thank you do much for the offer. It is my rear wheel. Luckily there is still some great service from "some" LBS. Linden Cycles got me sorted. Shimano does not offer a conversion kit like some of the other hub manufacturers. Edited by Block
