Maker Bike Warranty Drivetrain Suspension Brakes Fr. Der. Rear Der. Cassette Shifter Tires Price
Titan Racing Rogue Sport 5 year 1x10 SR SF14 RAIDON AIR 100MM MT200 Hydraulic Disk - Deore Deore Deore VITTORIA BARZO 29″ X 2.25 26TPI R11 999.99
Titan Racing Rogue Cruz 5 year 2x9 SR SF14 XCR AIR 100MM MT200 Hydraulic Disk Altus Altus Altus CS-HG200-9 Altus VITTORIA BARZO 29″ X 2.25 26TPI R9 999.99
Trek Marlin 5 Lifetime 3x7 SR Suntour XCT 30 Coil Tektro MT276 Hydr Altus Altus Tourney CS-HG200 Altus Bontrager XR2 Comp, 30 tpi, 29x2.20'' R9 999.99
Giant Talon 2 Lifetime 2x9 SR Suntour XCT30 HLO 29 TKD 143, hydraulic Altus Acera Altus CS-HG200 Altus Maxxis Rekon 29x2.4 R10 480.00
Giant Talon 3 Lifetime 2x8 SR Suntour XCE 29 TKD 143, hydraulic Altus Tourney Tourney tz Altus Maxxis Rekon 29x2.2 R9 548.00
Specialised Rockhopper Lifetime 2x8 SR Suntour XCE 29 Radius CX7, mechanical disc Altus Tourney TX 800 Sunrace 8 Spd microSHIFT Ground Control Sport, 29x2.3 R9 500.00
Specialised Rockhopper sport Lifetime 2x9 SR Suntour XCM 29 Tektro HDM275 Hydr Altus Altus Sunrace 9 spd Altus Ground Control Sport, 29x2.3 R11 200.00
Scott Aspect 970 5 year 3x7 Suntour XCE28 Tektro SCM-02 Mech MicroShift FD-M20 Tourney TY 300 Sunrace CSM40 7AV Tourney TY Kenda Booster 2.4" / 30TPI R9 490.00
Scott Aspect 960 5 year 3x7 Suntour XCE28 Tektro HDM275 Hydr Altus Tourney TX 800 Sunrace CSM55 8AV Altus Kenda Booster 2.4" / 30TPI R10 490.00
Scott Aspect 950 5 year 2x9 Suntour XCT30-HLO Hydr Tektro HDM275 Hydr Altus Altus Altus CS-HG200-9 Altus Kenda Booster 2.4" / 30TPI R11 999.99
Silverback Stride HD Lifetime 3x7 VAXA 860 Coil NUTT Hydr Tourney FD-TY-300 Tourney TY-300 Tourney CS-HG200-7 Altus CST C1820 2.35" R8 999.99
Silverback Stride Sport Lifetime 1x8 SR Suntour XCE28 Tektro MD-M275 Hydr - MICROshift 8s MICROshift 8s MICROshift Xpress 1 x 8spd CST C1820 2.35" R9 999.00
Edited by DuSeTwa
Updated warranty info
Alright lads
I had some spare time at work today and am trying to decide what a good starter bike would be for some trail riding and potentially daily commute. I kept the price below R12k to free up some budget for gear.
I threw the above table together but can't really piece together what the best value bike would be. It is interesting how different a lot of the bikes may be at the same price.
Please mention any additional bikes that I should add to the list and I will try keep it updated it maybe?
P.S. I left off some bikes like Fuji because I am 195cm and their bikes don't go above L.
Edited by DuSeTwa
Left a sentence out
It is clear from that table that the two Titan bikes are in a totally different league as the rest.
14 minutes ago, AkwA said:
I would look at the Rogue sport, Stride and Aspect
Is a 2nd hand bike off the table?
Can find pretty good bikes for 10-12k with very little use
The Rogue Sport yes. Seems like damn good value.
The Silverback Stride, nope. That VAXA fork is made by Zoom. I have one...on a Silverback Stride...not great is an understatement. The other Stride is Suntour XCE28 - just a hair better than the VAXA. Crappy rear derailleur options as well.
The only Scott on there that is almost worth looking at is the Aspect 950. Coil fork, Altus derailleur, 2x9. The Titan Rogue Sport blows it out of the water in all respects for the same price.
Edited by Rolf Hansen
Buy the Rouge Sport 1X10  Best Fork of the Lineup and Brakes that Will Stop U. (This is a R14999 Value Bike)
Stock Might be an Issue.
Edited by dasilvarsa
Second hand isn't at all off the table, I've been patiently waiting for a decent XL bike to crop up :)
I was surprised the most by Scott. Seemed like they were seriously overselling the brand factor at this price range. They would probably make a really respectable bike at the 15k+ region though!
2 hours ago, RobertWhitehead said:
Lets build you one for your budget
I'm all ears!
I thought about getting an old frame and then getting some sweet new parts.
But how far has the frame tech moved since say 2012?
11 hours ago, DuSeTwa said:
I'm all ears!
Some folks may argue that the tech has changed a lot since then but IMO if you wanted to go for a Hard Tail I do not see much difference between the geometry of a 2012 - 2015 model versus what we see on the market at this present moment. The frame colors have changed ????. But one thing you also should also note is that building opens a whole new can of worms, you can easily max your budget with only half a bike.
