I have the following issue. My hub was taken apart for a service and the axle shaft was found to be snapped(pic attached).
Any ideas on where to find a hub shaft for a Shimano FH-M678 free hub (142 x 12mm) or one that will fit. Apparently Coolheat doesn’t have any stock.
Thanks in advance
Maybe Someone on the Hub Will Say "I have One For You"
Otherwise the Next Assembly UP is the HUB
Phone Coolheat. They might Have the Hub Assembly.
Good Second Hand Wheel is another Acceptable Option.
Edited by dasilvarsa
Guess what "I have for you..."
Its a 142 x 12mm shaft which came off a FH M8010 part (XT 11sp hub). This is brand new
I also have the old 11speed XT hub body too, but this is stuffed and needs a rebuild if you want to try mate the 2 parts together
You can pm me - its your for mahala or a pay it forward sometime to someone else
20230908_060505.jpg.081f38bcd39024e4f5263c1ec3c6b270.jpg20230908_060007.jpg.81c43c740a5cb7072856bf41cc21b2c7.jpg
Edited by 117
Added peechas
that is awesome. 👌 Well done on helping this chap out!!
That is AWESOME!!! Just what I need.
I'll send you a DM
