Where to find RockShox Suspension Oil, 15 Weight (15wt)
King Wakanda
Good day
I plan to do a 50/200 hour service on my Rockshox Golden RL. I plan to do it myself but I'm missing one crucial thing, suspension oil, specifically the RockShox Suspension Oil, 15 Weight (15wt). It is the one that is listed in the Sram manual book for fork service. I tried looking for it online and it seems to be available only outside SA. Does anyone know where I can buy this suspension oil?
I contacted one bike shop and they told me that they don't sell the oil to customers, one other bike shop mentioned that they even use motorbike suspension oil on the bike forks. I'm not sure what any other type of oil will do to my fork, is there anyone who uses other available alternative suspension oil to service their fork?
UPDATE:
Thanks for all the advice guys, I learned a lot about oils and viscosities and all!
Edited by King Wakanda
Update
Link to comment
Share on other sites
3 minutes ago, dasilvarsa said:
I'm using Motul and It's working Fine
Got it From a Bike Shop in Edenvale City.
I have exactly the same - also from motorbike shop in the Vale 😁 - Works perfect
Link to comment
Also Couldn't get the RockShox Original.
I've done the same .... just pop in any old motorcycle shop.
Also, and you probably know this already, make sure you use a quality 24mm socket, not a shifting  spanner or worn-down socket. That top screw is soft, and not very deep, you can damage, or worse strip the corners in an instant.  ;) enjoy .
Edited by EddieV
Link to comment
I have no problem using the best for my multi thousand rand fork
You use less than 20ml per service for most forks, so does it really cost that much...
Its less than 50c per ml, so R10 per service
Edited by AkwA
Link to comment
4 hours ago, dasilvarsa said:
They Don't have the 15w for Lowers.
They Have 3wt Maxima 5wt RockShox  (For dampers)
and RS Reverb Fluid (For Seatposts)
correct. posted it as an interesting channel to go direct. guessing it is omnico (ccs) themselves
edit:wrong distributor, where is the strikethrough admin?!
Edited by Shebeen
Link to comment
The OP is looking for 15W not 10W or 20W
Of Course you can Mix But that is a Science on It's Own.
Half 10W and Half 20W does not give you 15W
Link to comment
https://www.widman.biz/English/Calculators/Mixtures.html
Not all 15w oil is the same either though👀
The viscosity (cSt) is more important
It really isnt that difficult and servicing forks arent that much of an exact science
Link to comment
Thanks for the reply. I'm really trying to find the original before I switch to alternatives. I wonder where the bike shops themselves get this oil, I mean are they all buying from overseas? Do you use this Motul on a Rockshox Golden RL too? Of it's not giving you problems I guess it can work for me too
Link to comment
