I am doing the sabieX for the first time towards the end of the year. Could anyone advise me on what type of tires   I should go with? (I am not after brands names but rather the type of tire for the terrain). I have decided to go tubless.
Thanks smiley1.gif Deep Section2008-11-03 03:21:02
I used Kenda small block 8 and also found they handled the wide variety of terrain - loose rock, sharp shale, tree roots, soft sand, hard pack and mud.  Tubeless is definitely the way to go - just make sure you choose tires with strong sidewalls.  You don't want to slash a tire at the top of Hartebeesvlakte (always a possibility).
mountain king's will be alright for the time trial would be better if you could get something mud specific for example the Bontrager mud X
also there is a lot of mud at the sabie experience so tubeless is a good idea but dont forget the mudguards
I used Kenda small block 8 and also found they handled the wide variety of terrain - loose rock' date=' sharp shale, tree roots, soft sand, hard pack and mud.? Tubeless is definitely the way to go - just make sure you choose tires with strong sidewalls.? You don't want to slash a tire at the top of Hartebeesvlakte (always a possibility).
Thanks for the advice.I have been seriously considering the Kenda small block 8. My only concern is loose gravel on the climbs and mud (if there is any around at that time of year?)
cut cutcut
dont be concerned be very worried!!!!
cut cutcut
Right.................
larger Nobs then?
cut cutcut
larger Nobs then?
Bontrager mud X you wont be sorry
Small block 8's and mud will be a disaster. Try wet rocks and cornering with them too if you wanna perfect crashing your ass off.
I perfected that already but in my case I doubt it's a tyre issue .............. Ouch
But then again if it rains like it did last year' date=' tyre choice is immaterial.
Borrow holy's drop  bar toeclips bike, and put slicks onLOL
cut cutcut
larger Nobs then?
Unless it ends up being dry and mud free...
thats why i have two sets of wheels smiley1.gif but if you dont have two sets of wheels take two sets of tires it takes me less than half an hour to change both tires if they are tubeless
