For those interested.
You can work out the power/weight yourself if you waqnt to compare it to your own figures. - my weight is 73kg.
Suikerbossie 1 is an extract from the "race"
Suikerbossie 2 is as a result of going back to give my wife some moral support.
 Argus 2007:
    Duration:      2:54:32
    Work:          2004 kJ
    TSS:           239 (intensity factor 0.907)
    Norm Power:    240
    VI:            1.26
    Distance:      108.212 km
        Min    Max    Avg
    Power:           0    892    191     watts
    Heart rate:      50    186    162     bpm
    Cadence:         21    141    94     rpm
    Speed:           0    73    37.2     kph
    Pace             0:49    0:00    1:37     min/km
    Hub Torque:      0    35.7    7.7     lb-in
    Crank Torque:    0    114.5    19.8     N-m
Chappies:
    Duration:      10:12
    Work:          165 kJ
    TSS:           20.2 (intensity factor 1.093)
    Norm Power:    290
    VI:            1.07
    Distance:      4.362 km
        Min    Max    Avg
    Power:           0    630    271     watts
    Heart rate:      157    182    174     bpm
    Cadence:         48    109    87     rpm
    Speed:           0    59    25.5     kph
    Pace             1:01    0:00    2:21     min/km
    Hub Torque:      0    31.9    14.9     lb-in
    Crank Torque:    0    81.3    30.3     N-m
Suikerbossie 1:
    Duration:      6:52
    Work:          107 kJ
    TSS:           11 (intensity factor 0.98)
    Norm Power:    260
    VI:            1
    Distance:      1.823 km
        Min    Max    Avg
    Power:           148    331    260     watts
    Heart rate:      166    180    174     bpm
    Cadence:         58    98    80     rpm
    Speed:           12.2    26.2    15.9     kph
    Pace             2:17    4:55    3:46     min/km
    Hub Torque:      12.7    26.1    19.8     lb-in
    Crank Torque:    19.6    51.3    31.3     N-m
Suikerbossie 2:
    Duration:      8:05
    Work:          125 kJ
    TSS:           12.9 (intensity factor 0.98)
    Norm Power:    260
    VI:            1
    Distance:      1.756 km
        Min    Max    Avg
    Power:           91    489    259     watts
    Heart rate:      57    169    144     bpm
    Cadence:         36    86    61     rpm
    Speed:           6.9    19.5    13.0     kph
    Pace             3:05    8:42    4:36     min/km
    Hub Torque:      7.5    49.5    24.0     lb-in
    Crank Torque:    12.4    122.8    40.8     N-m
Windbreaker2007-03-12 08:09:08
He was probably pushing his wife - same power' date=' but greater mass to move up the hill.
[/quote']Igzakly!
The other thing that that is interesting is when I was in "survival mode" during the race (trying to get back onto the bunch) my cadence was much higher than when I rode it the second time "casually" but I was generating the same power.
Windbreaker2007-03-12 08:25:45
took me 4:45s(just 10s faster than last year out of D bunch) and I weigh 73kg aswellLOL Guess I am not thaaaaaaat slow going up, well I looked slow doing it with the VA bunch, that must take the Giro Guys like 2-3mins? Marius2007-03-12 09:16:39
Guest colonel
Marius: You were on my wheel you must of been haulling up Sbossie!!!
Here's mine. I started in VA but punctured before Smits and rode the rest with B group. So the race time is the time I was moving (excluding the puncture stop). Actual finish time was 2:55.
I'm 61kg if you want to do the w/kg thing.
Race:
    Duration:      2:49:51
    Work:          1869 kJ
    TSS:           217 (intensity factor 0.877)
    Norm Power:    241
    VI:            1.31
    Distance:      107.5 km
        Min    Max    Avg
    Power:           0    897    184     watts
    Heart rate:      63    182    149     bpm
    Cadence:         29    141    89     rpm
    Speed:           0    71.2    38.1     kph
    Pace             0:51    0:00    1:35     min/km
    Hub Torque:      0    31    6.8     lb-in
    Crank Torque:    0    101.9    20.3     N-m
Edinburgh Drive:
    Duration:      2:49
    Work:          58 kJ
    TSS:           7.6 (intensity factor 1.271)
    Norm Power:    n/a
    VI:            n/a
    Distance:      1.176 km
        Min    Max    Avg
    Power:           66    562    344     watts
    Heart rate:      101    101    101     bpm
    Cadence:         76    138    92     rpm
    Speed:           20    33.9    24.9     kph
    Pace             1:46    3:00    2:24     min/km
    Hub Torque:      2.8    30.4    17.0     lb-in
    Crank Torque:    5.8    62.4    36.9     N-m
Smits:
    Duration:      4:07
    Work:          72 kJ
    TSS:           8.7 (intensity factor 1.129)
    Norm Power:    n/a
    VI:            n/a
    Distance:      1.723 km
        Min    Max    Avg
    Power:           0    601    293     watts
    Heart rate:      n/a    n/a    n/a     bpm
    Cadence:         55    131    86     rpm
    Speed:           20.2    31.8    24.8     kph
    Pace             1:53    2:58    2:25     min/km
    Hub Torque:      0    23.8    14.5     lb-in
    Crank Torque:    0    69.1    32.7     N-m
Small Chappies:
    Duration:      2:49
    Work:          54 kJ
    TSS:           6.5 (intensity factor 1.179)
    Norm Power:    n/a
    VI:            n/a
    Distance:      1.281 km
        Min    Max    Avg
    Power:           130    594    318     watts
    Cadence:         72    141    92     rpm
    Speed:           23.3    34.8    27.0     kph
    Pace             1:43    2:35    2:13     min/km
    Hub Torque:      5.5    27.2    14.2     lb-in
    Crank Torque:    10    69.1    34.2     N-m
Big Chappies:
    Duration:      5:10
    Work:          101 kJ
    TSS:           12.4 (intensity factor 1.198)
    Norm Power:    329
    VI:            1.01
    Distance:      2.346 km
        Min    Max    Avg
    Power:           81    628    325     watts
    Cadence:         62    138    88     rpm
    Speed:           18.6    51.4    27.3     kph
    Pace             1:10    3:14    2:12     min/km
    Hub Torque:      2.9    27.3    15.2     lb-in
    Crank Torque:    7.2    69    36.1     N-m
Suikerbossie:
    Duration:      4:57
    Work:          97 kJ
    TSS:           11.5 (intensity factor 1.179)
    Norm Power:    n/a
    VI:            n/a
    Distance:      1.897 km
        Min    Max    Avg
    Power:           192    598    326     watts
    Cadence:         67    133    84     rpm
    Speed:           18.5    33    22.9     kph
    Pace             1:49    3:15    2:38     min/km
    Hub Torque:      9.7    24.1    17.2     lb-in
    Crank Torque:    23    67.9    37.5     N-m
Here are my stats for the race.  Haven't had much time to analyse them yet, but my 5min peak power happened during Suikerbossie (duh) and I had a NP of 450watts during that time.
From Suikerbossie to the finish I did around 350watts.
 Race:
    Duration:      2:47:30
    Work:          2289 kJ
    TSS:           239.8 (intensity factor 0.927)
    Norm Power:    306
    VI:            1.34
    Distance:      108.456 km
        Min    Max    Avg
    Power:           0    1125    228     watts
    Heart rate:      63    179    147     bpm
    Cadence:         30    141    80     rpm
    Speed:           4.2    73    38.9     kph
    Pace             0:49    14:17    1:33     min/km
    Hub Torque:      0    39.8    8.3     lb-in
    Crank Torque:    0    152.9    28.3     N-m
Entire workout (196 watts):
    Duration:      3:55:38
    Work:          2753 kJ
    TSS:           287.6 (intensity factor 0.858)
    Norm Power:    283
    VI:            1.45
    Distance:      132.971 km
        Min    Max    Avg
    Power:           0    1125    196     watts
    Heart rate:      63    179    138     bpm
    Cadence:         29    141    78     rpm
    Speed:           0    73    34.0     kph
    Pace             0:49    0:00    1:46     min/km
    Hub Torque:      0    41.7    7.7     lb-in
    Crank Torque:    0    152.9    24.8     N-m
Peak 5s (1080 watts):
    Duration:      0:05
    Work:          5 kJ
    TSS:           n/a
    Norm Power:    n/a
    VI:            n/a
    Distance:      69 m
        Min    Max    Avg
    Power:           1028    1125    1080     watts
    Heart rate:      140    149    144     bpm
    Cadence:         91    111    103     rpm
    Speed:           45.9    52.4    49.5     kph
    Pace             1:09    1:18    1:13     min/km
    Hub Torque:      24    29.3    26.3     lb-in
    Crank Torque:    89.9    117.4    101.2     N-m
Peak 10s (912 watts):
    Duration:      0:10
    Work:          9 kJ
    TSS:           n/a
    Norm Power:    n/a
    VI:            n/a
    Distance:      142 m
        Min    Max    Avg
    Power:           688    1125    912     watts
    Heart rate:      139    155    146     bpm
    Cadence:         91    118    107     rpm
    Speed:           42.8    55    50.5     kph
    Pace             1:05    1:24    1:11     min/km
    Hub Torque:      15    29.3    21.9     lb-in
    Crank Torque:    55.6    117.4    82.4     N-m
Peak 20s (771 watts):
    Duration:      0:20
    Work:          16 kJ
    TSS:           n/a
    Norm Power:    n/a
    VI:            n/a
    Distance:      277 m
        Min    Max    Avg
    Power:           475    924    771     watts
    Heart rate:      169    178    173     bpm
    Cadence:         93    99    96     rpm
    Speed:           48.2    50.3    49.3     kph
    Pace             1:12    1:15    1:13     min/km
    Hub Torque:      11.5    22.1    18.8     lb-in
    Crank Torque:    46.3    89.1    76.5     N-m
Peak 30s (692 watts):
    Duration:      0:30
    Work:          21 kJ
    TSS:           3.7 (intensity factor 2.096)
    Norm Power:    n/a
    VI:            n/a
    Distance:      409 m
        Min    Max    Avg
    Power:           335    924    692     watts
    Heart rate:      164    178    171     bpm
    Cadence:         77    128    97     rpm
    Speed:           45.6    50.3    48.7     kph
    Pace             1:12    1:19    1:14     min/km
    Hub Torque:      8.8    22.1    17.0     lb-in
    Crank Torque:    25    89.1    68.5     N-m
Peak 1min (534 watts):
    Duration:      1:00
    Work:          32 kJ
    TSS:           4.9 (intensity factor 1.71)
    Norm Power:    n/a
    VI:            n/a
    Distance:      457 m
        Min    Max    Avg
    Power:           264    718    534     watts
    Heart rate:      158    173    168     bpm
    Cadence:         62    90    78     rpm
    Speed:           24.7    30.3    27.3     kph
    Pace             1:59    2:26    2:12     min/km
    Hub Torque:      12    32.3    23.5     lb-in
    Crank Torque:    35    91.4    65.3     N-m
Peak 2min (485 watts):
    Duration:      2:01
    Work:          59 kJ
    TSS:           7.4 (intensity factor 1.488)
    Norm Power:    n/a
    VI:            n/a
    Distance:      840 m
        Min    Max    Avg
    Power:           246    718    485     watts
    Heart rate:      161    175    171     bpm
    Cadence:         62    90    77     rpm
    Speed:           20.8    30.3    25.0     kph
    Pace             1:59    2:53    2:24     min/km
    Hub Torque:      12    32.3    23.3     lb-in
    Crank Torque:    34.5    91.4    60.0     N-m
Peak 5min (428 watts):
    Duration:      5:01
    Work:          129 kJ
    TSS:           15.6 (intensity factor 1.365)
    Norm Power:    450
    VI:            1.05
    Distance:      2.256 km
        Min    Max    Avg
    Power:           76    718    428     watts
    Heart rate:      149    178    172     bpm
    Cadence:         54    108    80     rpm
    Speed:           20.4    63    26.9     kph
    Pace             0:57    2:56    2:14     min/km
    Hub Torque:      3.3    32.3    20.0     lb-in
    Crank Torque:    9.3    91.4    51.6     N-m
Peak 10min (339 watts):
    Duration:      10:01
    Work:          204 kJ
    TSS:           22.9 (intensity factor 1.172)
    Norm Power:    387
    VI:            1.14
    Distance:      5.227 km
        Min    Max    Avg
    Power:           0    714    339     watts
    Heart rate:      136    179    162     bpm
    Cadence:         49    141    82     rpm
    Speed:           19.9    62.4    31.4     kph
    Pace             0:58    3:01    1:55     min/km
    Hub Torque:      0    35.5    14.6     lb-in
    Crank Torque:    0    88.8    40.4     N-m
Peak 20min (308 watts):
    Duration:      20:01
    Work:          370 kJ
    TSS:           38.5 (intensity factor 1.074)
    Norm Power:    354
    VI:            1.15
    Distance:      14.067 km
        Min    Max    Avg
    Power:           0    780    308     watts
    Heart rate:      141    178    163     bpm
    Cadence:         34    141    84     rpm
    Speed:           20.4    67.6    42.2     kph
    Pace             0:53    2:56    1:25     min/km
    Hub Torque:      0    32.3    10.6     lb-in
    Crank Torque:    0    103.7    36.3     N-m
Peak 30min (292 watts):
    Duration:      30:01
    Work:          526 kJ
    TSS:           54.8 (intensity factor 1.047)
    Norm Power:    346
    VI:            1.18
    Distance:      20.592 km
        Min    Max    Avg
    Power:           0    924    292     watts
    Heart rate:      63    178    160     bpm
    Speed:           20.4    67.6    41.2     kph
    Pace             0:53    2:56    1:27     min/km
    Hub Torque:      0    32.3    9.8     lb-in
    Crank Torque:    0    118.2    34.1     N-m
Peak 60min (260 watts):
    Duration:      1:00:01
    Work:          935 kJ
    TSS:           99 (intensity factor 0.995)
    Norm Power:    328
    VI:            1.26
    Distance:      40.256 km
        Min    Max    Avg
    Power:           0    924    260     watts
    Heart rate:      63    179    154     bpm
    Cadence:         34    141    83     rpm
    Speed:           19.9    67.6    40.3     kph
    Pace             0:53    3:01    1:29     min/km
    Hub Torque:      0    35.5    9.1     lb-in
    Crank Torque:    0    118.2    30.9     N-m
niterider, do you have the exact (to within 500m) distances of the start of Edinburgh Drive &  smits? Had a few "spurts which confuse the picture for both climbs. Wish PT would come out with a CPU with an internal altimeter!
niterider' date=' do you have the exact (to within 500m) distances of the start of Edinburgh Drive &  smits? Had a few "spurts which confuse the picture for both climbs. Wish PT would come out with a CPU with an internal altimeter!
I'm just guessing mine. Also wish there was an altimeter Disapprove
