Surely the torque settings are stamped on the bar, or in the literature that came with it? Measure with torque wrench...
A mate told me a simple trick if you don't have a torque wrench (he races bikes locally, and builds bikes when not racing them). Use soft fingers on the bike tool - tighten until you can't anymore without stiffening up your fingers.
It is surprisingly accurate.
Do yours not indicate to what NM they should be tightened to ?
Yes, NM as in Newton Meters... of torque....
And yes, you can get a wrench suitable for this at most hardware stores, it will for sure be cheaper than getting one at a bike shop...
And yes' date=' you can get a wrench suitable for this at most hardware stores, it will for sure be cheaper than getting one at a bike shop...
Yes but some of those does not go as low as 5nm. Some only start at 20.
Well, yes, but I figured the guy would check before buying that the tool will do the job...
So if I cant find said measurements - what should I use as an estimation? Or is this asking for trouble?
take it to your LBS - you would actually be rather surprised to find out that a lot of them do not even use torque wrenches.
i do all my carbon to carbon 5.5 NM.
actually went out and bought a torque wrench after cracking my first carbon seat post and use the thing at least once a week!
That is why Probike must get their arses in gear and start stocking these from BBB.
http://www.bbbparts.com/products/accessories/tools/images/torquefix.jpg
Yip 5 Nm is the norm, that is what ITM stipulates as well...........
And here is the big trick....you need to buy a special small torque wrench to get this as the normal industrial ones don't go that low....
Price ?? About R4k
Doc I assume that you use it on your seatpost as well?
yep - i torque everything - even the alu to alu stuff.
washed my bike once and the rear deraileur came off the bike in my hand - suspect it was not tightened  properly and the road vibrations just loosened the  nuts over time.
