Howdy.
I recently decided to bling out my rm7 .
I purchased some kcnc bling rear derailer jockey wheels..
awesome bling bling bits.
But ........ after installing the second jockey wheel one closest to the ground
my chain now doesnt seem to want to seat / run smoothly on the new teeth it tries to jump off , so you get the click click noise while pedaling.
changing gears etc does nothing to fix this .
its a shimano xt rear derailer .
as soon as i put the old wheel back the noise went away..
any ideas hot to fix? id like to keep the anodised ones on but need to fix this ..
bling bling goes well with new chain, if your chain has a few km on it, it is going to do that, the way the chain worn on the chain blade and cluster is different to every bike, and your rear derailer wheel worn in on the chain, the reason why the noise goes away on the old wheels.
hope this helps
did happen exactly the same to me about 3 weeks ago
ended up being a bit expensive, had the original nylon pulley wheels but were worn badly so i decided to get some good derailer pulley wheels ( KCNC ) but also skipped a lot
bought new chain & voila skipping stopped immedeatly
hope this helps
Have you got the wheels the right way around? I know on my Shimano the top wheel is slightly narrower than the bottom and can shift slightly from side to side on the bush, while the bottom has no play - otherwise they are identical.
Have you got the wheels the right way around? I know on my Shimano the top wheel is slightly narrower than the bottom and can shift slightly from side to side on the bush' date=' while the bottom has no play - otherwise they are identical.
KCNC wheels are identical and that is why I stopped using them. There is a reason why original manufacturers make things a certain way.
I agree. Certain things should be kept original. Those blue, gold, pink etc jockey wheels looks silly in anycase.
i also bought this bling kcnc jocky wheels.
I also had a noise after installed.
but...... I did not put the chain back correctly. Tongue  so it rubbed against the jocky arm... hehehe
The BEST pulley wheels are those made by the groupset manufacturer like Mampara says, the KCNC and others are always a compromise cuz they made to fit many variables and thus can cause hassles...
had to endure this from my partners bike for the whole of sani2c... and every 2nd oke offering to help him adjust his gears.
