Where can I find mineral oil for my disk brakes?
Seems like the lbs's don't stock them. One shop offered to sell me a bottle for R35 with enough oil to bleed one brake.
I can order from crc, but I'd like to have it as soon as possible.
Guest coenie
Ask Johan Borman, he would be able to tell you what to get I think that it is DOT4, but not sure then you can get it from Midas......
Ask Johan Borman' date=' he would be able to tell you what to get I think that it is DOT4, but not sure then you can get it from Midas......
DO NOT PUT DOT4 BRAKE FLUID IN A MINERAL OIL BRAKE SYSTEM!!!!
I've heard you can get from a motorcycle dealer
I use shimano, so I need mineral oil. DOT will ruin my seals or whatever.
I'll try a motorcycle shop. There's one not far from where I live.
Guest coenie
Hmm why not?
https://www.bikehub.co.za/forum_posts.asp?TID=84368&KW=dot&PID=1167910#1167910
https://www.bikehub.co.za/forum_posts.asp?TID=83950&KW=dot&PID=1163516#1163516
Like I said I do not know what Shimano uses
If you go to any good bike shop they should have. If they don't. they can get within a day or two from the local agents.
If you use any other oil than what is prescribed by the manufacturer your warranty will be void.
Ask Johan Borman' date=' he would be able to tell you what to get I think that it is DOT4, but not sure then you can get it from Midas...... [/quote']
Hmm why not?
Brakes use either Dot 4 or Mineral Oil,
Shimano most definately uses mineral oil
Hmm why not?
HUGE difference between DOT$ and any mineral oil!!!
like they said...do not use the wrong oil with the wrong brake system...on the other hand you do not have to pay hundreds of bucks for the generic oil either...just stick to the same kind
Use motorex hydraulic oil . Perfect for all brake systems . You can also get the mineral hydraulic oil from mercedes , they use the oil in the active suspension models .
