hi all
i am looking into buying myself a polar watch or monitor for my bike. it is basically a choice between the watch type(CS300) and the cycle specific(CS400) one. i see they both have way more than enough settings and things too check your training, heart rate, planning,altitude etc. is it really needed too have all these settings?
i obviously want too get the most out off the product, so will i use all this? cause i dont really see the point in paying alot for something that i am not really going too use.
and who has these products and use all the settings? or should i go with more simple?
I use a polar 725 and cannot function without it.
It can be used for running or cycling (or any other event that gets your heartrate up) is waterproof so it can even be used while swimming.
It is one of those purchases that keeps on giving.
I can honestly advise to buy the polar.
2teeth
As jy gewoont is aan jou Polar wil jy nie meer sonder een ry nie.. Ek het n 725i baie nice.. ek kan sien as ek siek word.. mens kan alles daar sien.
Had the 720i and now the CS600.  Bike specific.
The more gadgets / toys / settings, the cooler it is to play with........
Get what you can afford and enjoy!!
Positives about the Cycle specific:
It stays on the bike.
Easier to mount on flat bars
Looks better.
Negatives:
You cannot take it to the spinning class around your wrist.
Can't wear it while having sex.
Good luck!!!
i used to use a CS200 (the 300 - 600 were not out when i bought it) and
i loved it, gave me all the info i needed. upgraded to a S725X and i
love it even more, the main reason for the upgrade i guess was for the
power meter functionality that the CS200 does not have.
i guess the question to ask yourself is, what do i need? if you need
heart rate, speed and cadence, the CS300 or even CS200 will be a good
buy. if you need altitude, temp etc..  you may need a more expensive
model.
wrt cycling only or watch type, i guess thats a personal preference, i
dont ever wear my 725 as a watch, maybe only when i drive to my morning
rides, and that is only because i dont like leaving it on my bike when
the bike is on the caddy!
Negatives:
Well you could put it in the condom to give yourself some girth.
That way it will serve a dual purpose....just remember to wear your hr belt as well...
