hi all. i have ridden about 1500km on my bike and my local lbs say its nearly time to get a new chain. i find this very wierd, considering the low mialege. what is the typical mileage one gets on a road bike chain?
I'm on 2000km with my chain and it does not even look like it's done any work. My 105 chain lasted 12000km and I only replaced it beause I thought it was time.
Get at least 5000 km out of a 10 speed Dura Ace chain,but I do clean it 3 times a week and lube properly afterwards.Cleaning part seem to be the secret.
Same problem! Took my bike in for a pre-AmaShova check. (Scott Speedster 10 with ultegra components) Bike has been running smoothly so I was very surprised to be told that my chain was "fish curry"!!!! The chain is less than 3000km and I clean and lube it before every ride. Worse still is that my cassette, which I put on new for the Jock has suffered some damage as well. I was given a crash course and demonstration on a bike's drive train and I must say my attitude received a sharp adjustment. Appears that a chain can last only 400km but some can last 4 000km. Depends on how well your drive train is set-up!
MichaelH2007-10-03 02:06:48
"PM" Johan Bornman and get the right info.
Or go to his website and read up on it.
You cant just say "a chain gets XYZ milage" there are other criteria like hygiene etc, but check with Johan first.
it might be that you guys ride odd gear ratio's?
chains get very easily/quickly worn if you ride a 39x11 or 39x12.....those type of gear ratio. I have seen a lot of people riding this way!!
I would imagine it would be the small front and small back that would have an effect? i.e. 'cross chain' thingamajig! Also read somewhere that with modern drivetrains that wasn't so much of an issue.
yes they call it "crosschain" but ya.....those type of ratio's is one of the most common wear and tear causes. It took me a few months to "teach" my wife how to ride gears properly.....
yes' date=' i dont ride like that, i try ride on the big ring as much as possible, the small ring would wear out fast if you rode on it all the time [/quote']
The big ring aswell. If you use one more then the other, it will wera out faster.
that could be it....i rode this winter a lot on the indoor trainer and did ride a lot more hills so the strain you put on the chain is a lot more than just "cruising". So you doing big blade means more strain on the chain so it wont last as long as my wife's chain for example....she is almost never on the big chainring so the stress on the chain is not that much.....uou know what i mean.
Soooo....that is why my chain lasts me 4 months my wife's chain...still OK after 12 months!Big%20smile
