MTB Wheelset weights - Tubeless & Tubes
Ive just been wondering what peoples wheelsets (tubeless or with tubes) weigh? Not been able to find much about it on the hub or anything for people full wheelsets for that matter. I know it will all vary depending on a lot of things - ie rims, tyres, how much sealant, spokes, cassette & hubs, etc etc.
I changed my tyre on the back wheel and the rear wheel now seems heavy. I am running No Tubes ZTR 355, with Conti Race Kings Tubeless 2.2, XT cassette & DT Swiss 370 hub, DT Swiss Dbl butted spokes(32 hole) - This rear wheel came in at 2.1kg. Not sure on the front yet but am running the ZTR rim, Kenda Nevagal(non UST) & Hope Pro 2 hub & DT Swiss Dbl butted spokes.
I'm just interested to see what people are running, I know weight is not the big issue here - I found the bike to be rolling much faster then before.
  • Replies 49
2.1kg seems right, I have American Classic with RaceKing 2.2 UST, SRAM X0(Red) cassette with Hope 140mm disk weighing 2.0kg. UST tires are usually +-700g so unless you changed TO a UST FROM a Tube-Type then it will feel a bit heavier.
Went from Geax Barro UST - Just the whole bike feels heavier or I got weaker :(
Here are the weights of some heavy wheels and tyres so you guys can appreciate what you have
Complete tyres, tubes, slime, casettes, skewers, discs and air
Alex XD Lite with Kenda Small Block Eights (on my bike)
Front - 2038g
Rear - 2510g
Alex ACE 17 with Cheng Shin (on girlfriends bike)
Front - 2390g
Rear - 2930g
Different tyres will naturally have different rolling resistance so just changing the tire can change how the bike rolls. Also a tire effects the weight/bike handling the most.
@chris_w_65
Wow those are impressive weights :-)
Just built my wheels and weighed them before I added the cassette, tires and rotors. (Had the Valve on). could have made them lighter with Aluminium nipples not they would not be as strong.
Front
Stans Alpine Rim, DT Swiss revolution Spokes, Hope Pro 2 hub = 690g
Rotor Claimed weight = 104g
Tire Intense System 2 Claimed weight = 500g
Slime Stans 2oz = 57g
Skewer = 62g
Total = 1413g
Rear Wheel
Stans Alpine Rim, DT Swiss revolution Spokes, Hope Pro 2 hub = 800g
Tire Kenda Small Block 8 Non Tubeless Claimed weight = 500g
Skewer = 75g
Total = 1536g
My wheels are anchors but compared to you guys that have spend so much on wheels, they do not compare too bad.
Wheels are build using Mavic 717 rims, black DT swiss DB spokes, XT 756 hubs, stock skewers, black DT swiss brass nipples, CST tubes (yes I still use tubes), Maxxis Aspen 2.1 non-UST tyres and Alligator rotors (160mm front, 140mm back).
Front = 1731
Back = 2160
@chris_w_65
Front
Skewer = 62g
Total = 1413g
Rear Wheel
Skewer = 75g
Total = 1536g
Lets us know what they weigh completed :)
So for interest sake Captain Sarcasm, what does your wheelset weigh?
well what did you expect, next suggestion is for tt bike designers to
'think aero'?
dunno. bike is about 12 and i don't believe that theory about 'light wheels' accelerating faster.
'think aero'?
I just asked what peoples wheelsets weigh, then wondered why the tyre companies dont make a inbetween tyre - No need for the sarcasm was there really.
'think aero'?
Seeing as were pointing out the obvious. Its not just a theory, its the wieerd and wonderful world of science
Please can someone explain the weird & wonderful too me :)
Very simply (Force in a straight line)
F = ma
F = Force (power available in your legs :))
m = mass (of the whole bike in this case. i.e. the wheels contribute to this this total mass)
a = acceleration
re-written with respect to a
a = F/m
Now assuming constant F, a will increase as m decrease
Getting more technical (Centripetal force - Force that makes the wheel go round)
F = ma + (mv^2)/r
F = Force (power applied to the wheel)
m = mass (mass of the wheel)
a = acceleration
v = velocity (straight line velocity of the wheel at a point in time at r)
r = radius (from the center if the wheel to the "center of gravity")
Again, re-writing with respect to a
a = F/m - v^2/r
So by the same logic. a will increase as m decrease.
Now for the kicker...
The total weight of the wheel is not as important as where the weight is. Similar to the logic behind a weight increase resulting in a acceleration decrease, the same applies for a increase in r. Basically the further away the weight is from the center the more of an effect it has on acceleration.
Summary. Light wheels DO accelerate faster and reducing the weight of the Tyre/Tube/Slime and Rim is worth much more that reducing the weight of the Hub and Skewer.
Hope this helps.
