what lubricant do you use? I have used everything and i find it all picks up grit. i am using motor oil at the moment which i find works an absolute treat, but does pick uo alot of dirt, on my road bike.
  • Replies 52
Motor Oil is a disaster, pics up loads of dirt which will erode your drivetrain. Use a cycling specific product. I use squirt, works great, also had good results with White lightning. You also need to keep the chain clean, and reapply regularly, overapplication will also get dirty.
One word, Squirt.
Now Admin, can you please sticky threads regarding lube, seats, tyres, tubes, toilet paper, snot blowing and Maria Sharpova.
Mampara2007-11-14 00:24:03
Boeshield T-9
If its good enough for Boeings .......
Tongue ha ha. Indeed it is............
Q20 works wonders. A little secret SShhhhh* (Sewing machine oil)
Must disagree, think squirt is the largest load of shyte I have ever used on my chain. I'm using the Motorex stuff at the moment and works for me.
Gone back to using plain old oil and is working fine.  Probably better than Squirt.  You don't need much and it keeps the drivetrain quiet.  Have ridden in dust, rain and mud recently and not had any issues.  Wax based lubricants don't seem to handle the wet that well.  On the MTB I replace the lube after washing my bike as the chain gets washed at the same time.
