Do any other hubbers have a similar problem ? I have continious buzzing comming from both shifters when riding . I have checked a few other forums where they refer to the brake end not being seated into the correct "side" of the holding device on the brake lever , but I have checked that and mine are . I also checked that its not coming from the shift paddle neither as I pull them towards the handlebar and the "buzzing" is still there . I am going back to the lbs today , maybe they know a quick fix ?
Sute it's not your tyres :rolleyes: :lol:
Hope you come right man. When you say buzzing, you mean that vibrating sound? My sora shifters do the same thing - it has a rubber stopper at the back of the brake levers - they have gotten a tad flat lately and have started vibrating.
Try riding and gripping the top of the shifters / brake levers to squash the levers against housing.....
Thanks for the response guys , I have tried gripping the brakes slightly , then the noise/buzzing goes away . Its definately not the shifter paddle touching the brake lever causing it . I have looked at the SRAM website technical section and they say that the brake mechanism inn the hood needs a little grease , I dont know if that will help though .
Even if I lift the front wheel off the ground and drop the wheel down you can hear the resonating vibration , it almost sounds like there is a tiny little part loose inside , The strange part is that it does it on front and rear shifters
Do you by any chance ride deep section carbon wheels?
Nope , Mavic Aksium , its definately not the whhels as I have just changed from 105 and had no vibration at all . Thanks for your suggestion though .
Dude, it's either that the rubber stoppers in the shifters are worn OR that there aren't any in.... well there should be really.
Pull the brake lever and look behind it - I have a rubber grommet looking stopper that the lever rests against to stop the vibration.
Tiny , are you talking about a stopper that sits inside the hood , or at the back of the brake lever between the paddle shift and the brake ?
inside the hood - will be between the brake lever and the back of the hood - where the two come together.
