Hello Guys
I went tubeless about 2 mounts a go. Is there a scale of sum sort where you can see
how meany bar's your tyres need 2 be according 2 your weight? I am heavy... 111kg's.
The one guy at the shop i did my conversion said tubeless should not go over 2bar's
but another guy at another bike shop said i must run my back tyre at a min of 2bar's cos of my weight.
What bar's must my tyres be at? front 1.8bars and back 2bar's? And what is the min and max for tubeless?
bike: hard tail 26
tyres: Xkings continental
trails: WC.. lots of sand and small rocks.
Id like to know which shop it was that said you should not inflate over 2 bar. Personally I never run less than 2 bar, usually 2.3 bar. Only when conditions are exceptionally sandy would I run 2 bar.
Running a too low tyre pressure risks damaging the tyre bead especially when going over rocky terrain and/or doing drops etc. Rather get a fatter tyre and run a higher pressure.
Tyre pressure should be terrain dependent. If there is the slightest chance that a rock will cause the rim to bottom out against it, up the pressure.
I can see why people want to ride with tyre pressure as low as possible - traction is good then.
However, a dented rim could spell the end of your ride or race. With new-tech rims such as Stan's rims that don't have a long sidewall, a dent could spell the end of the rim. Older rims absorb the impact in the sidewall, which can be bent back by a skilled mechanic. Stan's rims absorb the impact directly in the rim cavity.
I am 98kg and still run 1.8-2bar, but it is tricky now as on some seated climbs with dips in them i bottom out. so at 110kg i would say run between 2 and 2.2 bar depending on tire.
My rule of thumb is if I bottom out seated on a climb grinding I am probably just under pressure. When going down I am normally out of the saddle so a the legs are also part of the shock system so not much of an issue there.
It was a shop here in the cape. don't want 2 name names. Think he may have been one of the young guys that helps out now and then.
I tip the scale at 80Kg and ride 1.6-1.8 bar, works for me... just dont know why anyone would ride tarmac with this MTB... :unsure:
Because they don't have two bikes and they wish to get in some distance training that they can't at their local trails?
To all: Do these numbers differ dramatically if you are using tubes?
no wonder my ass is taking strain on 2.5bar, im only 70kg.
any recommendation for what i must run my tubeless?
I'm 60kg and ride at 1.2 at the front and 1.5 at the back.
Maybe 0.1 more for you, or 0.2...
Also depends where you're riding.
have x king protection, fairly new to these tyres (not UST but ride them tubeless) weight eh hem 74kg, had on 2 bar this weekend and although really fantastic on crawling over rocky terrian i felt overall things were a bit bumbpy, will experiment with lower pressures on the next ride
