What's everyone's gear ratio's, thinking of buying a new crankset(actually new campy groupset) and trying to figure out if I should go for a compact crank.
How would a 50/34 with a 11-23 casette work? Would I have the same top end speed of a normal double but with a 12-25 casette in the back and better climbing gears?
  • Replies 32
Try this link from FSA for an explaination: http://www.fullspeedahead.com/downloads/compact.pdf
Interactive spreadsheet for comparisons: http://www.fullspeedahead.com/downloads/copy_Rollout%20chart .xls
I must admit I havent read through it myself, but have looked at the comarisions and comments from other people and understand that the 50/11 gear is a bit faster than a 53/12 gear on the flats (for the same cadence), and the 34/23 is a bit easier than a 39/25 gear on the climbs.
The advantages are a slighly lighter drivetrain (smaller chainrings, smaller cassette and a shorter chain) and closer gear ratios. Some people say that a compact (more curved) front mech is required while others say that a properly adjusted from mech is sufficient. Shimano doesnt do anything special, but FSA and Campy have compact front mechs.
Good luck with your desicion and enjoy your new groupset!
splat38933.3538657407
Splat has it spot on.  50-11 is as near as dammit to 53-12 as you would care to be, and 34-23 is about 39-26.  So you lose nothing but have a wider spread of gear options.  It is true about compacts dropping the chain more often as the jump from 50-34 is much bigger than 53-39.  Despite that I don't see myself ever riding a 53-39 again.
I've got a 50/34 - 11/23 and the 34/23 was used quite a bit at the top of boulders smileys/smiley9.gif, however I think that for 95% of races, with racing up and down rolling hills  a 50/36 would be better as there is a huge gap between the big and small chainring. If you are a LA wannabee and go up hills spinning like a MTBer in the granny gear then get the 34!
Can I make the assumption that for me to convert my current crankset (53/39) to a compact will only entail changing the crankset itself, nothing else?
Ratio = 50 * 27 / 11
 39533650
1195.72727130.090988.36364122.7273
1287.75119.2581112.5
1381110.076974.76923103.8462
1475.21429102.214369.4285796.42857
1570.295.464.890
1665.812589.437560.7584.375
1761.9411884.1764757.1764779.41176
1858.579.55475
1955.4210575.3157951.1578971.05263
2052.6571.5548.667.5
2150.1428668.1428646.2857164.28571
2247.8636465.0454544.1818261.36364
2345.7826162.2173942.2608758.69565
2443.87559.62540.556.25
2542.1257.2438.8854
Assuming the the crankset you choose uses the same bottom bracket, you should be A for AWAY! (I dont think that there are any Q factor issues).
You would have to drop your front mech slightly and possibly shorten your chain a bit.
Splat, I got a FSA Gossamer crankset with external bearings and a 31.8mm clamp on front der.  Would I only have to buy the crankset?
Take one link out the chain, drop the front derailleur about 5mm and you are done. No need for a compact derailleur, a friend has one and I don't, neither of us drops the chain very often (not more than I did before anyway).
I use a 25-12 for training and a 21-11 for racing with a 50/34 up front, its the best thing since sliced bread.
I have one of those "can't drop your chain from the small ring" type thingys on my bike!  Thanks Sir Fred, now to get a LBS that stock them and pricing in cold JHB!
ewep: if the compact crank you buy uses the same BB as your current one, you are ready to go. Your LBS should be able to sort you out.
Does anyone in Jhb know of a LBS that stocks FSA?  I've phone Cyclelab and Westdene cycles and no one has a crankset available.
