Help comparing spec sets please - 1st "real" bike
diverdi
Hi. Following on from my thread yesterday ("Upgrading from 10-ish year old Avalanche Tundra"), I would appreciate some opinions from people on some bikes I've been offered in my intended price range - R4000 - R6000.
First option: Momsen AL126 2012
Frame Race Tech 1, Alloy 6061 Tubeset
Fork SR Suntour XCM RL, Remote Lockout Lever
Chainwheel Shimano M361 42/32/22T
Bottom Bracket Cartridge Type
F. Derailleur Shimano Acera
R. Derailleur Shimano SLX
Shifter Shimano M390 Trigger Type
Brake Levers Tektro Draco Hydraulic
Brakes Tektro Draco Hydraulic
Cassette Shimano HG20 Cassette, 11-32T
Rims Weinmann ZAC2000, 32H
Tires Kenda Small Block Eight 26 x 2.10 60tpi
Pedals Alloy Platform Type
Handlebar Alloy Riser, 31.8mm Oversize
Stem Alloy Forged, 31.8mm Oversize
Seatpost Alloy Micro-Adjust
Seat SR Seta
Headset Ahead Type, 1.1/8"
Colors Matte Black w/Red Details
Chain KMC 9 Speed
Hubset Shimano Centerlock, 32h
Spokes Stainless Steel
Grips Kraton Comfort
Second option: Silverback Alpine 3
Frame / G2 Force Alloy
Fork / Suntour XCR LO Lock-out 100mm - Alloy Steerer
Rims / Alex TD25 Double Wall Aluminium
Hubs / Shimano RM66 Center lock
Tyres / Kenda Small Block Eight 26" x 2.1
Shifters / Shimano SL-M390, 9 Speed Rapidfire Plus
Front derailleur / Shimano M390
Rear derailleur / Shimano Deore Shadow
Crankset / Shimano M391 Octalink 22/32/42T
Bottom bracket / Shimano ES25 Octalink
Cassette / Shimano HG20-9 Speed, 11-32T
Pedals / VP Components
Brake set / Shimano M445 Hydraulic Disc
3rd option: Silverback Alpine 2
Fork / Suntour Raidon X2 Air Lock-out 100mm - Alloy Steerer
Shifters / Shimano Alivio 9 Speed Rapidfire Plus
Front derailleur / Shimano Alivio
Rear derailleur / Shimano SLX Shadow
Crankset / Shimano M430 Octalink 22/32/44T
Cassette / Shimano HG50-9, 9 Speed 11-32T
Option 4: (a push financially!!!!) Momsen AL129
Frame Race Tech 2, Alloy 6061 Butted Tubeset
Fork RockShox XC30 Turnkey Lockout 100mm
Chainwheel SRAM E400 44/32/22T
Bottom Bracket Cartridge Sealed
F. Derailleur SRAM X5
R. Derailleur SRAM X5 9 Speed
Shifter SRAM X5 Trigger
Brake Levers Tektro Hydraulic
Brakes Tektro Hydraulic
Cassette SRAM PG950, 11-32T
Rims Weinmann Alloy, 32H
Tires Kenda 26 x 1.95"
Pedals Alloy Cage
Handlebar Alloy Riser , 640mm x 15mm Rise, 31.8mm Oversize
Seat Momsen Race
Headset Ahead Type
Chain KMC 9 Speed
Hubset SRAM 306H, 32h
Spokes Stainless
Grips Kraton
As you can see all but the last are 26inchers. I'm 1.67m with inner leg measurement of 79cm so I'm not so sure about the 29inch bike. Also I'm sure there are other bikes I could look at but these are the best specced ones I've been offered in this price range. (I'd love to pay less and the Silverback Stride 10 is one such option here.
To date I have been sticking to riding on the road (existing bike has slicks). A couple of hubbers are doing their best to convince me to go offroad. Lets assume I will still do a fair amount of road riding with some dirt riding. Which would be better on both surfaces - the 26 inch or the 29 inch with knobblies or would they be fairly similar?
Main aim: fitness and weight loss!! I work weird hours so most of my cycling is likely to be done alone - when I'm not working everyone else is and vice versa!
Link to comment
Share on other sites
  • Replies 37
If you do allot of riding alone, then I'd def rather look at MTb'ing.
there are various parks around where you can ride safely alone, alone on our roads today, I'm def not keen on.
G
Link to comment
IMO this bike from Solomons in Woodmead is a better option for R6000.
SIZES S (15"), S/M (17"), M (19"), M/L (21"), L (23")
COLOR(S) Black/Red
MAIN FRAME A1-SL alloy w/ PowerCurve down tube, hydroformed top tube, oversized seat tube and semi-integrated head tube, double water bottle mounts
REAR TRIANGLE A1-SL alloy w/ S-bend stay, cold forged dropout and disc mount w/ replaceable hanger
FORK SR Suntour XCR w/ hydraulic-speed lockout, 100mm travel
REAR SHOCK N/A
CRANKSET Shimano M522 Hollow Tech, 24/32/42T
BOTTOM BRACKET Shimano octalink
PEDALS FPD w/ alloy cage
FRONT DERAILLEUR Shimano Deore, 34.9mm
REAR DERAILLEUR Shimano Deore XT SGS top normal, 10-speed
SHIFTERS Shimano Deore Rapid Fire, 30-speed
CASSETTE Shimano Deore, 11-34T 10-speed
CHAIN KMC X10, 10-speed
WHEELSET Fuji mountain disc 32H hubs, Jalco AX430 alloy disc rims
TIRES Hutchinson Scorpion 26x2.0 or Kenda K-837F/K-848R ATB, 26x2.1"
BRAKE SET Tektro Draco hydraulic disc, 160mm rotor
BRAKE LEVERS Tektro Draco hydraulic disc
HEADSET Fuji custom 1 1/8" semi-integrated, 30mm spacers
HANDLEBAR Fuji alloy riser bar, 20mm rise, 6° sweep, 31.8mm, 640mm wide
STEM Fuji forged alloy w/ removable faceplate
TAPE/GRIP Fuji dual density kraton
SADDLE Fuji sport mountain w/ steel rails
SEAT POST Fuji alloy micro-adjust, 31.6x350mm
Edited by scotty
Link to comment
Hi guys. Multiquote seems to not be working this morning so:
@ awesme: fortunately there are a number of very quiet roads in my area at the times I am able to ride so not too much of an problem for me. I know I enjoy it so I do want to keep road cycling as an option.
@Skandalis - R5000
@Scott - a lot of what Solomons have on their website they don't have stock of - I know because I've been to see them and called with follow-up questions. Not 100% sure which bike you've listed the specs of - the Nevada 1.0 maybe? I can contact them to ask if they have that one in stock however it is on the extreme of the "may consider" price range so please tell me why specifically this one as opposed to say the Silverback Alpine 2 (my option 3)? And if I went for it which of the tyre sets would most likely work better for me (since I see there's a choice) - the Hutchinsons or the Kendras?
Thanks..
Link to comment
Welcome to the Hub. Fyi Kendra was a potentially attractive blondie, until she opened her mouth and, anyway with that Hef guy...
The tyres that you mention, are Kenda. Good luck with your choice and I hope you have many hapy miles..
Link to comment
LOL... sorry about the typo.
But this isn't helping with my choice of bike ! :huh:
Link to comment
You see, you'll never find the bike in a budget X that has all right components Y. Somehow we are obsessed with owning the latest gear spec, even the average rider wouldn't really notice a difference between a 2012 SRAM x7 or a 2013 XT. All bikes in your price range would have won world champs 7 years ago, so of it is fitness and fun you're after they all serve you well - get out, make a choice and enjoy the ride.
Link to comment
ibruegge - those are probably valid points - I just don't want to blow money because I do not see myself upgrading - can't justify it.
Scott - Solomon's don't have stock of the Fuji you recommended unfortunately..
Link to comment
You probably can't go wrong with any of the bikes mentioned.
I'm vouching for the AL129 cause I have one & love it to bits. Would let it sleep next to me if I could :ph34r: Just double-check the price with Solomons (If that's where you got the quote), as I paid R4 500 for mine a couple of weeks ago.
And don't forget do budget for all the other kit :whistling:
Link to comment
You have the AL126 if I remeber correctly. Very capable bike with really good quality components.
Also looks great in black.
Personally I think you cant go wrong with that. Great value for money that will last a lifetime.
Link to comment
Hi.
Skandalis, so did you get your AL126 at Solomons? If so it seems they no longer have stock, only have the AL129 (which I have pretty much decided against because I'm not convinced I want to go 29inch NOR pay the higher price.) If elsewhere please tell where :)
The AL126 quote I got was from Westrand.
After reading up all day I was leaning towards one of the Alpines based on the forks because it seems the XCR or the Radion are better than the XCM..?
But good to know you're loving yours - its still in the mix for sure.. - especially if I can find it for R4500!
Link to comment
Yip, got it from Solomons. Saw one on their shop floor today. Strange that they said they don't have stock though as they were willing to order one in for me at the time... Surely not much can change in 3 weeks?
Whichever you choose, hope you have a blast. My only regret is not getting into the sport sooner!
Link to comment
Hmmm. Maybe the salesman is just trying to push the more expensive 129... I'll double check on Monday. Thanks for the info! :thumbup:
Link to comment
