I had one on my old bike and it took a lot of punishment without much complaint. Required the odd adjustment from time to time, more so after munching some dirt, but didn't fail me once.
Do it!
Deore is near the bottom of the Shimano range but more than adequate for beginner/intermediate riding. If you're going to be hitting the marathons and racey/expert stuff then I would recommend spending a bit more and getting to the SLX range.
I know many people that have ridden Acera and Deore components for years without hassle.
  On 7/18/2013 at 10:52 AM, muckanddirt said:
Has anyone got anything bad to say about the deore range of derailers. I am looking to buy one of these bikes (http://www.silverbac...spectra2_13.htm ; http://www.giant-bic...sc/12797/59400/) but a mate of mine told me stay away from the deore derailer. I am confused.
It's mid range but not too bad for the price. However the Silverbacks Acera shifters and front derailers I would not recommend.
I'm sure the 2012 Spectra had SLX on the rear and Deore on the front, I wonder whats with the downgraded spec?
Deor is a perfectly good entry level groupset. best way i can describe it is, its the worst of the best if that makes sense.
its really not a bad groupset, to put it into perspective the following may prove useful: its not the hard and fast rule but its a pretty good representative sample
current mountain bike groupsets include:
Cross country component mid to high end range
* XTR (9 speed) - Top of the range for cross-country mountain bikes
* Deore XT (9 speed)
* SLX (9 speed) New in 2008, replaces Hone and LX
* Deore (9 speed) Entry level cross-country mountain bikes
Downhill/Freeride component stupidity range
* Saint (9 speed) - Top of the range for downhill and freeride bikes, and many components are based on the XT groupset
* Hone (9 speed) - discontinued in 2008, replaced with SLX
Recreational mountain bikes component cheap makro/ game range
* Alivio (8 speed)
* Acera (8 speed)
* Altus (8 speed)
* Tourney (7 speed) - Includes several different levels of quality, and can be found on department-store bicycles
Edited by DaddyG
There is nothing wrong with Deore's quality. It shifts as good as XTR. If you ride with a properly adjusted Deore and you don't know it, you can't tell what's on there. I'm phrasing this badly.... In a blind test, you cannot tell. The more expensive derailers have more aluminium parts on and are machined nicely. But they all shift the same.
I have ridden marathon's, trans baviaans, 24 races etc... on with a Deore deraileur, no problems whatsoever, good precise shifting and easy to adjust. I switched to XT a year ago, when the Deore wore out after about 8 years and don't notice any difference, except the really irritating fact that the XT doesn't have a rear barrel adjuster, so you have to set up your gears at the shifter. XT is much much prettier though.
I had a Deore 8 Spd on my previous bike, altus front derailleur, acera shifters, can't remember what cheap crank but anyway it worked well. I had nothing to complain about. If you clean/lube your components regularly it would work like a dream.
And from what I gather you are no bike expert so I reckon you won't notice the difference between a XTR and Deore derailleur so don't waste your money on a "lighter/fancier" derailleur, it won't benefit you at all.
