To finish it off with some Ritchey classic parts
http://zpravodajstvi.ivelo.cz/img/1366_3214_full.jpg
http://www.biketiresdirect.com/productimages/images450/ricsm2-1.jpg
http://jedi-sports.de/images/product_images/popup_images/2645_0.jpg
http://cyclesbespoke.com/wp-content/uploads/2012/08/Ritchey-Classic-Stem1.jpg
  • Replies 130
Faaarking hell that's insanely cool! I knew I should never have started polishing the frame :) At this rate I'm probably going to start polishing the cranks next :)
It's the right thing to do...
Thanks to some inspiration from divernick a-polishing I did go. Cheated a bit by buying a polishing attachment for the drill from the local Builders Warehouse but it's still pretty much a dirty and LOOONG process. Pictures of the polished frame without any wax on yet.
Did you sand it first befor polishing ?
:) I hear you brother :) So much for "I'll just polish this little bit here, oh, and now this bit here, and here, and here .." :)
I used the paint stripper, then lightly sanded the entire frame using a fine sanding block and water, only once it was pretty smooth (but still quite dull) I switched over to using the polishing attachment on the drill. Maybe I should do an entire thread on the tech Q&A and detail the process?
