I got one for Xmass. Problem is that when I plug the unit in to my computer it does not pick it up. Is my software outdated or should I rather download n driver from the internet. Thanx
Does it not pick up at all? Try another usb port, make sure your usb drivers are up to date.
Does it not pick up inside certain programs eg fittrack, sporttrack? Make sure you downdloaded garmin communicator plugin and it is active
Edited by Mailman7412
Make sure you use the USB cable that came with the 500.
Not sure why but my 500 only works with the Garmin cable supplied and no other.
Edited by alsoran
