Good day Hubbers.
Time for new brake pads.
I have got Shimano BR M596 brakes.
Which in your opion are better resin or metal pads?
From what I can see metal last longer but make more noise?
Any other pointers?
thanks
WRT Resin: If you are doing multi day rides and there is any chance of rain then rather put in metal, as resin will disappear in a couple of km's of mud. Then you have no brakes and your ride is effectively a mess. Also if you do have this problem and you expect wet weather always carry a spare set of metal pads in your pack.
Anyone who has done muddy multi day races will be familiar with this. Resin is a no no.
So because of this i run metal in almost all my bikes
I changed from resin to metal and hated every minute I rode with them. Changed straight back to resin. Wet weather and mud I can agree metal will wear better but for all other riding the resin performance is absolutely tops.
And just because it is Monday :
Many disc brake pads are available in different compounds
Medium Compound
Also known as Compound S (Medium)
Containing metal and graphite for long wear. Great for muddy conditions, and a good choice in all conditions. A medium compound with consistent wet performance and good grip.
Advantages: Cheap, Above average all around performance
Disadvantages: Grippier and longer lasting pads are available
Suitable For: Everything
Conclusion: Best Value
Superlight WorldCup Competition Alu Backed Pads use the medium compound.
Professional Grade Black Ceramic Compound
Also known as Compound C (Ceramic Pro)
These soft organic ceramic fiber disc brake pads are carbonized. The ceramic compound insulates the brake system from friction heat up to 400oC. The result is a very powerful, quiet pad with extremely low heat generation which all but eliminates the chances of brake fade.
Details
Upgrade on original fitted pads
DIN 79100 Standard Approved
Organic Compound contains no metal material
Reduces damage to rotor
Carbonized compound reduces brake fading
Ceramic Fiber insulates brake system from friction heat
Non-Asbestos
Advantages: Excellent grip, Low noise, Low heat, Consistent in all conditions
Disadvantages: Short life span unless rider is light on brakes
Suitable For: DH, Dry XC, Ti Rotors
Conclusion: Best Performance, Short Life
Metallic Sintered
Also known as Compound T (Sintered)
Superior power in all conditions
Long wear pads, great for DH or XC
Consistent braking power in the wet
Almost unaffected by rain and snow
Advantages: Better performing and longer lasting than most pads
Disadvantages: More expensive than medium pads
Suitable For: XC, DH (low brake use), All weather conditions, Mud
Conclusion: Best All Rounders
Red Ceramic Compound - Hard
Also known as Compound D (Ceramic Hard)
Harder than ordinary pads. This is the highest density, hardest, ceramic compound for ultimate performance and the longer lifetime. These organic disc brake pads contain a high amount of ceramic fiber, which insulate the brake system from friction heat up to 400oC.
Advantages: Better performing and longer lasting than medium pads
Details
Non-Asbestos
Advantages: Longer lasting than Black Ceramic pads
Disadvantages: More expensive than Black Ceramic pads and not as grippy
Conclusion: Ceramic Advantages with Longer Life
Other Factors
Low Noise: The black ceramic compound C is thought to be virtually silent
DH: Black Ceramic pads are great for Downhill as the ceramic compound insulates the calliper pistons from heat build up so reducing the likelihood of brake fade.
Rotors: All of these compounds can be used with any rotor. Ceramic pads cause less damage to rotors than metallic compound pads. Titanium Rotors: We recommend black ceramic compound for titanium coated rotors, as it contains no metal, so will reduce damage to the rotor. The coating on titanium plated rotors is extremely thin (often just a few microns), so will ultimately wear off no matter what pad you use, but ceramic pads will prolong their life over pads containing metal.
Just curious Dirt Rider, all these additional compounds are they from after market companies? I have only ever seen one or two shimano variations. Usually metal sintered and Organic/Resin.
