Building a Cyclo Cross bike
Meerkat82
  • Replies 2.2k
Just needing some linear pull drop levers like the Tektro RL520s
do you still need those if you're running disc?
Yes, if they are MTB disks which have the same pull as V-brakes.
If they are road disk brakes, then you can use standard levers.
ahh, got you, made the mistake of assuming you;re running road calipers, although they might be an easier find that the levers you're after?
possibly, but I reckon the levers will be cheaper. I already have the disk calipers. Levers are £16.50 on Chainreactioncycles
So bought a set of cheap aero levers to set the bike up with in the meantime. They'll work, but maybe not optimally. But hey they only cost R175, so I'll keep them in the spares drawer.
The next question is......
Gears or SS
Gears or SS
Go with gears if you are going to ride it off the beaten track....
Gears or SS
 gears
That is going to be amazing! Shorten your stem and add spacers to lift it up. Remember your hoods need to be where your current flat bar is, that will take some adjusting and fiddling
Have a shorter 35 degree stem to raise the bars and bring them back. Failing this I'll have to get a stem extender
