BB' date=' I'm a little confused as to why you used a BMX tjoop? Why not an ordinary MTB one? [/quote']
A BMX tjoop is smaller (20/24") therefore a tighter fit over the rim to seal the spoke holes better.
  • Replies 170
[quote=lurker
Which LBS was that Lurker?
Olympic was telling me about a R250.00 UST conversion instead of the Stans or Joes (R500.00 +) system.
Flip I gotta keep on top of my freds here on the HUB! Sorry Jules I missed this.
But exactly as the gangsta says it gives a nice tight fit for better sealing Tongue
  • 3 weeks later...
just deflate and remove a small section of bead from the rim. Pour Joes/Stans or whatever in, and re-inflate. I'll put money on it you'll get it inflated using a floor pump. I've done this maaaaaaany times.
I want try the tubeless conversion on my road bike too...Just 1 question:
When the tyres are worn have to be replaced, how much of a mess is it when the tyre is removed and how difficult is it to clean the rim up for the new tyre?
Guest Big H
Not sure whether this was discussed. To seat the beads when fitting a tubeless tyre you need a quick blast of a volume of air quickly. Not many of us has compressors to do this but all of us have spare tyres. If you connet your tube to a car tyre with a length of reinforced air hose and two valve clips at each end and add a normal ball valve in the middle to controll the flow of air you have a large volume of air that is available quickly. Can also be used to "blowdry" a washed chain and other odd things. Just remeber to re-inflate your spare tyre as that would now be a calamity if you need it, would it not!!!!!!!!!
Guest Big H
When the tyres are worn have to be replaced' date=' how much of a mess is it when the tyre is removed and how difficult is it to clean the rim up for the new tyre?
Rather worry if you have a blow out on the rear tyre...... goo will be sprayed everywhere and it will be messy!!!!!!!!
just deflate and remove a small section of bead from the rim. Pour Joes/Stans or whatever in' date=' and re-inflate. I'll put money on it you'll get it inflated using a floor pump. I've done this maaaaaaany times. [/quote']
That's my plan! Will report back when necessary ...........
Big Bill ?
Big Ben? That name rings a bell...
Give it a bit of time and you might recall where you heard of him...
Word on the street is that he has a towering intellect...
Don't ever race against him: I hear he's a bit of a ringer...
