Would it truly be a fair representation of the 2016 Niner Jet 9 if you guys are testing a bike that doesn't have the same spec as the actual model?
Yes. Geometry and suspension design stays unchanged. No different than us testing a bike with SRAM X1 and based on that a buyer decides to buy one, but opt for Shimano XT 11spd.
Only major difference will be the Pike on the 2016 vs the Reba that's fitted to the one on test. That's an easy enough fix as I have a Pike I can try on there, but would most likely opt to try it with a Revelation as it would make more sense to me.
Thats not MAXXIS IKON tires on that bike
1. No reason to shout. (Insert smiley face here)
2. Read the article again. The one we have on test has a different spec than the 2016 models on their way in.
Niner's international website lists the 2016 3 star build as having a Pike set at 140mm, but the SA websites lists the Pike as 120mm. Why the difference?
