Spirog Posted April 7, 2016 Posted April 7, 2016 So, I have a pair of Fulcrum Racing Zero Nite wheels that I've been riding since December. Fantastic wheels. However, I have had constant issues with noisy brakes. I have replaced the brake pads which had worn down very quickly with the recommended Blue Campagnolo pads. The brake pads squeal like a Vuvuzela as soon as they start to grip. I have cleaned and adjusted them multiple times, but to no avail. Please help!!!
'Dale Posted April 7, 2016 Posted April 7, 2016 Gingerly apply coconut oil on the brieke before every ride. Just kidding. Check that the pads are fitted straight and not skew.Remember some vuvuzela soundtrack is normal with intensive braking. Spirog and 458Exp 2
Spirog Posted April 7, 2016 Author Posted April 7, 2016 Remember some vuvuzela soundtrack is normal with intensive braking.The problem is that now my mates know how scared I am because I brake so much... These start to squeal as soon as they start to touch the rim.
Butterbean Posted April 7, 2016 Posted April 7, 2016 Try out swisstop pads with the pads sent toe in. Place a credit card inbetween the back half of the pad and the rim, squeeze brakes, loosen and retighten cartridges. . Should sort it out. 458Exp and Christie 2
jcza Posted April 7, 2016 Posted April 7, 2016 Are the wheels carbon? If so, then you need red Campag pads. 458Exp 1
Martin PJ Posted April 7, 2016 Posted April 7, 2016 If all else fails, use furniture polish. Mr Min or Pledge. Spray on the braking surface before each ride and wipe off the excess with a tissue. It also keeps the wheels very clean and seems to make the braking surface last longer. Only works for carbon wheels though.
Spirog Posted April 7, 2016 Author Posted April 7, 2016 Try out swisstop pads with the pads sent toe in. Place a credit card inbetween the back half of the pad and the rim, squeeze brakes, loosen and retighten cartridges.. Should sort it out.Thanks, will try this.
'Dale Posted April 7, 2016 Posted April 7, 2016 Try out swisstop pads with the pads sent toe in. Place a credit card inbetween the back half of the pad and the rim, squeeze brakes, loosen and retighten cartridges.. Should sort it out. Brilliant.Read this before somewhere else. Sparked a memory. Spirog 1
Spirog Posted April 7, 2016 Author Posted April 7, 2016 Are the wheels carbon? If so, then you need red Campag pads. No, they are Aluminium with a black braking surface. Here's the link if you're interested. http://www.fulcrumwheels.com/en/wheels/road-bike-wheels/racing-zero-nite
'Dale Posted April 7, 2016 Posted April 7, 2016 (edited) The problem is that now my mates know how scared I am because I brake so much... These start to squeal as soon as they start to touch the rim. I know the feedback.All my buddies train with alu braking surfaces. HeheheThey get a skrik actually. Then again, there is the Law Of Silence. Check out velominati.com EDIT Cool alu hoops. Edited April 7, 2016 by Puncheur 458Exp and Spirog 2
jcza Posted April 7, 2016 Posted April 7, 2016 No, they are Aluminium with a black braking surface. Here's the link if you're interested. http://www.fulcrumwheels.com/en/wheels/road-bike-wheels/racing-zero-nite Yip the blue Campag pads are the correct ones, hope you get to sorted Spirog 1
Madone69 Posted April 7, 2016 Posted April 7, 2016 (edited) clean your brake surface properly . you could even just sand it lightly with fine sand paper . your pads too. the make of pads is not the problem , its a layer of dirt or even oil. used both swiss stops & campy pads .. they both squeal if dirty. Edited April 7, 2016 by Madone69 Spirog 1
Martin PJ Posted April 7, 2016 Posted April 7, 2016 I would try cleaning the surface with meths. There must be oil on it, or maybe the pads are contaminated. Spirog 1
Spirog Posted April 7, 2016 Author Posted April 7, 2016 Check out velominati.com I am a committed follower of The Rules. For those that don't know what Puncheur is talking about...http://www.velominati.com/the-rules/
Organic Posted April 7, 2016 Posted April 7, 2016 I had this problem with some Mavic rims. I tried the credit card thing, but it didn't help me. What sorted it out for me was the following: Find a friend, and a steep downhill with a wall next to it.Put the friend on the bike, facing downhill, leaning on the wall, with the rear brakes (only rear) firmly pulled.Loosen the brake screws a bit so that the pads can freely align themselves with the rim. Get the friend to wiggle around a bit. Tighten the screws.Repeat for front.
Register a new accountSign in
