Mongooser Posted October 13, 2016 Posted October 13, 2016 im looking for new brakes in the second hand market,not sure what to go for have bout 800 to spendwont use avid again,i've gone into way to many trees and other objects
popcorn_skollie Posted October 13, 2016 Posted October 13, 2016 Before you bash the brand. What was wrong with your brakes?
Mongooser Posted October 13, 2016 Author Posted October 13, 2016 Before you bash the brand. What was wrong with your brakes?lose power over time usually 2 months,then have to bleed again
Odinson Posted October 13, 2016 Posted October 13, 2016 Perhaps the seals are toast? How old are the brakes?
CdT85 Posted October 13, 2016 Posted October 13, 2016 Perhaps the seals are toast? How old are the brakes? ^^^^^This...check your brakes seals. if the piston are stuck in the calipers, no amount of bleeding will fix it. Just rebuild your calipers. Got rebuild kits for my elixir 5's from Revolution cycles recently.Was about R250 a set, plus R150 odd per bleed at my lbs
popcorn_skollie Posted October 13, 2016 Posted October 13, 2016 I'm assuming you have a set of elixirs. They're not bad brakes. I've had them all 1,3,7, SL, CR what ever. A full rebuild and bleed and you should be fine after 1 or 2 rides. At least that's what you can pull off for R800. Not sure what you're gonna get used for that budget. I mean you could score a decent set of formulas for about a 1k or so. But chances are that what ever you get at that price might need a build and bleed themselves at some point. So...
Mongooser Posted October 13, 2016 Author Posted October 13, 2016 brakes seals are fine,no fluid leaks,they are bout 3 years old id guessthey are elixer 5's
BaGearA Posted October 13, 2016 Posted October 13, 2016 For 800 bucks you are going to struggle to get anything that will stop you fast in a free-ride situation, maybe try some new pads and rotors. **** your pads may be contaminated , If they are metal pads soak them in acetone (1 hour) and burn off excess IF they are resin pads throw them away. Otherwise they could be devective and you could try to warranty them --edit spelling.
Duane_Bosch Posted October 13, 2016 Posted October 13, 2016 You should be able to get shimano deore's for around R800. I sold a pair for that. Power is ok. Feel is great. They aren't the most fashionable brakes but so what. I'd rather stop my bike with a stick in the spokes than Avid Elixirs.
Mongooser Posted October 13, 2016 Author Posted October 13, 2016 Post pics of the pads.brand new elixer pads in the back and front
Mongooser Posted October 13, 2016 Author Posted October 13, 2016 You should be able to get shimano deore's for around R800. I sold a pair for that. Power is ok. Feel is great. They aren't the most fashionable brakes but so what. I'd rather stop my bike with a stick in the spokes than Avid Elixirs.newer avids dont work as great as old ones
CdT85 Posted October 13, 2016 Posted October 13, 2016 brakes seals are fine,no fluid leaks,they are bout 3 years old id guessthey are elixer 5's Let someone like Droo look at the brakes for you. Owned multiple sets of Elixir 5's. After a rebuild and proper bleed they were all as good as new.Have the bladders in the levers checked out as well. Your R800 will be better spent on fixing them than buying a R800 brakeset that will need to be serviced as well. I posted a thread not to long ago about my "sick" elixir 5's and was about to chuck them, but got them sorted in the end. My only mistake was using the wrong bike shop to bleed them originally.
capediver Posted October 13, 2016 Posted October 13, 2016 You should be able to get shimano deore's for around R800. I sold a pair for that. Power is ok. Feel is great. They aren't the most fashionable brakes but so what. I'd rather stop my bike with a stick in the spokes than Avid Elixirs.You may be onto something! Eco-friendly, renewable resource, freely available, great range (oak, pine, khaki bos)......I'd be interested in what sort of modulation you get with that stick of yours? Also what about wear and replacement...do you need to carve new ones or can you just pick up any stick along the trail...How do you mount said stick? Same as your recent adventure at Steilte...just somer so?.....
JXV Posted October 13, 2016 Posted October 13, 2016 For R800 your budget is a little shy for newer better brakes. We can't easily tell from your descriptions if the pads or discs are contaminated or if the levers are faulty. Describe exactly what happens in detail....Do they fade as they heat up, do the discs just slip through with no friction, are the levers spongy or switchlike, Do the levers slowly collapse to the bar when you hold the brakes on hard, do the brakes squeal a lot, do they rub/drag when brakes are off .....each of these symptoms has a different cause Contaminated pads and rotors can be cleaned with acetone but remove them off the bike first and DONT burn them....it leaves greasy soot and residue. Acetone is water soluble so after soaking in acetone to remove oils, rinse in water and let them dry. Do the same with discs. Then re-assemble. Be careful with acetone it is ultra dangerous. You can also use isopropyl alcohol as an alternative. When you bleed, remove pads and insert bleed blocks. This way the brakes will be filled with the correct amount of fluid and any spillage will not contaminate your brake pads. To make your brakes more powerful within your budget consider fitting bigger rotors if you can.... 200 on front and 180 rear or 180 front and rear. The money will go on discs and mount adapters. New pads too if you can. Good luck. Sent from my SM-G935F using Tapatalk
Mongooser Posted October 13, 2016 Author Posted October 13, 2016 For R800 your budget is a little shy for newer better brakes. We can't easily tell from your descriptions if the pads or discs are contaminated or if the levers are faulty. Describe exactly what happens in detail....Do they fade as they heat up, do the discs just slip through with no friction, are the levers spongy or switchlike, Do the levers slowly collapse to the bar when you hold the brakes on hard, do the brakes squeal a lot, do they rub/drag when brakes are off .....each of these symptoms has a different cause Contaminated pads and rotors can be cleaned with acetone but remove them off the bike first and DONT burn them....it leaves greasy soot and residue. Acetone is water soluble so after soaking in acetone to remove oils, rinse in water and let them dry. Do the same with discs. Then re-assemble. Be careful with acetone it is ultra dangerous. You can also use isopropyl alcohol as an alternative. When you bleed, remove pads and insert bleed blocks. This way the brakes will be filled with the correct amount of fluid and any spillage will not contaminate your brake pads. To make your brakes more powerful within your budget consider fitting bigger rotors if you can.... 200 on front and 180 rear or 180 front and rear. The money will go on discs and mount adapters. New pads too if you can. Good luck. Sent from my SM-G935F using Tapatalki was told somethings wrong with the lever,i pump the brake then it only works for 5 secs,lever can be pulled flat onto the bars with no force on the rotor
