Can i use car rated Hydraulic fluid on my brakes
Mongooser
Can i use car rated Hydraulic brake fluid on my brakes,have a decent.bottle of the stuff hanging around would it work or do i need a special type of hydraulic fluid
Sent from my GT-I8190 using Tapatalk
No ! No ! No!
You will damage them.
Shimano uses Mineral oil and SRAM uses Dot fluid.
its dot 4 and 3 bottles,reason i ask is the rubbish they bleed my brakes with overheats and gets spongy to fast,cars fluid is way more heat resistant
Old fluid belongs in the trash. Shamano use mineral oil. Others use dot fluid. Read the instructions or you will stuff us the seals.
the bottles where bought this morning brand new brake fluid for dot 3 dot 4,i dont plan on doing the bleed myself,and get info from the mechanic
i have avid elixers
Avids run Dot fluid, not mineral oil like shimano. Dot 3 and 4 can be mixed.
Read the link posted before.
Just don't get the stuff on paint and brake pads.
so would the cars dot 4 and 3 not overheat as much as the cheap nonsense in my brakes?
Hey dude, I bleed my own brakes. I use car dot 4 or 5 and so far no problems. I would recommend going to bigger discs as this would help with the over heating. what size do you have?
185mm on back and 160mm up front,my bombers cant take a more than a 180mm i did run a 203mm on the other bike but had the same problem
The larger the Dot number, the higher the temperature rating.
As the fluid gets old, it absorbs water, decreasing the temp rating significantly - I would guess that's your problem.
Flush the brakes while its being bled, and use the higher Dot rating.
It's frighting how some ppls bikes are set up !! Bigger rotor needs to be up front ! Just use the correct fluid in your brakes !! If you running shimano use shimano fluid ! These things stop you , do you really want them failing because you cheaped out ?
