Giant Reign build: Seeking Wheels, Fork & Components
I recently acquired a 2010 Giant Reign X1 frame & starting to assemble all the bits & pieces for rebuild. Pls let me know if you have any wheels & components to sell.
I know Myles used to have one before it was forcibly removed from his possession, maybe he has some old bits lying about.  DM him and check. Myles Mayhew on here.
Ok, thanks so much
Why forcibly ??
Myles care to elaborate ?
You want a beefy 160-180 fork like a 36, 66, lyrik or totem.
So if you're looking to buy used. Place a wanted add. You might get lucky
Although, you could also consider a 650b pike or yari. If you pair that with a good drivetrain and cockpit. It will go a long way to making the frame and wheels upgrade more affordable when the time comes.
Don't settle for wheels less than 30mm wide either.
Get some hoops that were meant to take a beating. Flows, subrosa, s-types, something like that.
I've got 2 sets of 26" wheels I'd be willing to sell, don't actually own 26" bikes anymore. Axle configuration 135mm rear QR and 20mm front.
Not sure what the setup is on the reign.
Cool! Can you DM me what rims they are & the inner width of the rims? Needs to be wide, like 22 - 25mm.
