Bela Bela 5150 2017
EmJayZA
26 days to Bela Bela. Accommodation and entry booked and paid.
Who else will be there? Any tips or suggestions for us newbies? Anything worth seeing in the area?
  • Replies 72
The water is probably going to be freezing, suck it up. :)
Other than that, just have a great groovy day. Its going to test you make no mistake but enjoy it anyway. And don't stop event if it means crawling :)
Will keep moving, no matter what. I am pretty confident I am ready. I would have been able to do Durban, so I am really looking forward to this. Need to work on my race pacing. My goal time is 3.5 hours, which should look like:
Swim 34 minutes
T1 8 mins
Cycle 1 hour 20 mins
T2 5 mins
Run 1 hour 15 minutes
Feeling shaky on my bike. Had a spill which totally messed up my confidence, and switched to clipless pedals. So have been holding back and descending pretty slowly. Will hit the road as much as I can in the next 3 weeks to fix confidence issues.
Will post my times after the race. Going to be interesting to see if I can make my goal.
Swim 34 minutes
T1 8 mins
T2 5 mins
Excellent, those are pretty aggressive times esp the cycle but doable. Good luck. See you in the cradle
Will be doing my first triathlon!
Managed to get a road bike from a friend at least. Will need to get comfortable on the ridiculously skinny wheels, I've only ridden it once so far!
I will be chuffed with anything round 3 hours, but with no previous races, I have no idea what is good for me.
The swim at Bela Bela is easy (watch out for the walkers :-) )and the run is relatively flat but don’t underestimate the cycle leg it is tough.
Swim 34 minutes
T1 8 mins
T2 5 mins
Definitely doable overall time, here is a breakdown of my times of last year. Keep in mind the following:
My Swim is relatively weak(back of the pack),
My Bike is pretty strong(passed allot of people on the course)
I suffered on the run(got passed by plenty of peeps)
Swim:33:52
Total Transition 1: 5:00
Bike: 1h24:28
T2: 2:14
Run: 1h02 (my PB on a flat 10km route is 48min, so quite a bit slower)
Total 3h07
So I agree with IceCreamMan, your target cycle time might be a bit aggressive.
My bike time was about 10mins faster than those I finished with and my swim and run was about 5mins slower each compared to those around me. So it points out that I pushed a bit too hard on the bike and paid for it on the Run.
Swim:33:52
Bike: 1h24:28
T2: 2:14
Total 3h07
Thanks. Think it is prudent to add another 20 mins to my bike time and push a bit harder on the run.
Think a more realistic breakdown is:
Swim 35 minutes
T1 6 mins
Cycle 1 hour 40 mins (average speed of 24km/ph)
T2 4 mins
Run 1 hour 10 minutes
Try not to swallow too much water, it's not the cleanest !!
EmJay, I think your cycle time is optimistic, it is not a flat course, there is a fair bit of hills and climbing.
My splits from last year
Swim 28:38
T1 4:38
Cycle 1h 31 (am a fairly decent cyclist)
T2 2:04
Run 1h 01
Bear in mind, the race starts around mid-day, you cycle and run in the heat of the day, there is usually a fair bit of wind on the cycle leg and the previous 2 years I did the race the run was in 32-34 degs!
Use the race as a learning curve, analyse things that went right and went wrong on the day... try not to get stuck on achieving times/splits, and don't get down if they are not achieved.... there are many factors (the heat being a big part) as well as how you feel on the day that might affect hitting or missing your estimated times.
Enjoy and learn :)
[snip]
Aha, that reminds me, my stomach was propely upset that evening and the following day. :wacko: Definitely picked up a bug in that water!
Swim 28:38
T1 4:38
T2 2:04
Run 1h 01
Enjoy and learn :)
Thanks. Yeah, will still monitor HR (no power meter on bike) and try stick in my target zones. So I won't be too disappointed if I don't make my goal times. It's my second triathlon, and a journey so it's just a fun day out to me. But I do like seeing new PRs and higher numbers, so want to have a number in my mind and adjust how I feel on the day.
Been doing a lot of hill/big gear training specifically for this race (and potentially for Ultra Midlands). My problem is bike handling and confidence. That's slowing me down hectically. Things you guys do that are second nature, I have to still learn or master (like gearing properly, drinking from a water bottle while riding, clipping in and out, etc). Riding a bike well is certainly not easy and requires a lot of practice. So it's not all about fitness/power.
Only comes with time in the saddle
Mate I did the race with last year also had a dodgy stomach for a couple of days after
How many minutes will a wetsuit save? I'm not too fussed about swimming cold water.
Flip that water was surprisingly cold last year. My Garmin measured 18°C. Even with a wet-suit it was flipping cold, took my breath away for a moment as I entered.
Difficult to quantify how much time it will save you, if any, because you need to struggle for a moment or two to get the thing off as well.
I am not a strong confident swimmer, so the added buoyancy just gives me the little bit of confidence to do it. Personally I wouldn't easily do a swim portion without a wetsuit.
