Cube Stereo 120HPA Pro, Silverback Sido 3 or Titan Sonic Elite
Krukkie
Hi Everyone
I am new here and would like some advice. I am looking at buying a new soft tail and have narrowed it down to three bikes with similar specs, or so it looks to me as a rookie.
Frame : HPA Ultralight, Advanced Hydroform, Triple Butted, ATG, ETC 4-Link, AXH
Color : black´n´flashorange
Size - 27.5: 16", 18", 20" // 29er: 17", 19", 21", 23"
Fork : Rock Shox Recon Silver TK Air, PushLoc, 15mm Maxle, Tapered, 120mm
Shock : Manitou Radium Expert RL, 184x44mm, Rebound Adjust, Lockout
Shock hardware - Top: 30x8mm, Bottom: 22x8mm
Headset : FSA 1.5E ZS, Tapered, Top Zero-Stack 1 1/8" (OD 44mm), Bottom Zero-Stack 1 1/2" (OD 56mm)
Stem : CUBE Performance Stem Pro, 31.8mm
Handlebar : CUBE Rise Trail Bar Pro, 720mm
Grips : CUBE Race Grip, 1-Clamp
Rear derailleur : Shimano XT RD-M781-DSGSL, Shadow, Direct Mount, 10-Speed
Front derailleur : Shimano Deore FD-M617-D, Direct Mount, Side Swing
Shifters : Shimano Deore SL-M610, Rapidfire-Plus
Brake system : Shimano BR-M315, Hydr. Disc Brake (180/180)
Crankset : Shimano Deore FC-M617, 36x22T, 175mm
Cassette : Shimano CS-HG50, 11-36T
Chain : KMC X10
Wheelset : Answer Atac MA, 28/28 Spokes, 15mm / X12, Tubeless Ready
Tires : Conti X-King, folding, 2.2
Saddle : CUBE Active 1.1
Seat post : CUBE Performance Post, 31.6mm
Seatclamp : CUBE Varioclose, 34.9mm
Weight : 13.85 kg
Silverback Sido 3
FRAME SB Lightweight 6061 Alloy 29” Suspension, Tapered 1-1/8”-1.5” headtube, Pressfit BB Shell, Alloy Triangle with Dual linkages using 142 x 12mm Through Axle Integrated Dropouts, Replaceable Alloy hanger, XGuide Cable management System
HUBS Rear:Shimano Deore 142 x 12mm, Cassette, Black Front: Front:Shimano Deore 15x110mm OLD Boost Hub Spacing, Sealed Bearing, Disc Mount, Black
SEATPOST Sector Level 6061 Alloy, 30.9mm, L:350 for S Size
REAR SHOCK RockShox Monarch RT, 90mm Travel, 165x38mm
STEM Sector, 3D Forged, S/M: 80mm; L: 90mm; XL: 100mm, 7° x Dia 31.8mm, Black
TYRES Crossmark II 29x2.1". 53-622, Dual Compound, 60 Tpi, TR
SADDLE Sector Performance, Black
CASSETTE Shimano CS-HG50, 10 Speed, 11-36T, Silver
RIMS SUNringlé Helix TR 29", 32 hole drilling , Disc Only, Black Anodized, Tubeless Compliant
HANDLEBAR Sector Plane, Butted Alloy, W: 700mm; Back Sweep: 9° x Dia 31.8mm, Black
SHIFTERS Shimano Deore SL-M610, 2x10 Trigger, Black
CRANKSET Shimano FC-M500, 36/26T, L: 175mm All sizes, Black
BRAKE SET Shimano Deore BL/BR-M315, Open Hydraulic System, Rotors Front: 180mm; Rear: 160mm, Black
FORK Manitou Markhor, 29”, 100mm Travel, Solo Air, Tapered Alloy Steerer,15x110mm OLD Boost Hub Spacing, Black
FRONT DER Shimano Deore FD-M618-D, Direct Mount, Black
REAR DER Shimano XT Shadow Plus RD-M786, Long Cage, 10 Speed, Black
Titan Sonic Elite
Frame - Lightweight Hydroformed Aluminium Boost XC/Marathon Frame
Fork - Rock Shox Recon 100mm with Poploc
Rear Shock - Rock Shox Monarch RL Air
Crank & Chainrings - Shimano SLX M7000 36/26T
Rear Derailleur - Shimano XT RD-8000
Front Derailleur - Shimano SLX FD-M7025
Shifters - Shimano SLX SL-M7000
Speed - 22 Speed
Chain - KMC X11
It would be great if I can get some advice on which will be the best value for money and just the best overall. i also need to add that I am on the heavy side, 120kg and would need something that can handle the weight.
Thank you in advance
Silverback definitely the better between the 3 suspension wise
the titan has A better drivetrain tho
Silverback still wins in my books
If it were me I'd go for the Cube, it's got 120mm travel vs the 100mm travel of the other 2 and it's better looking IMO. You'll have to check if these bikes have weight limits. List the prices and a pic of each and you might get more response.
Thanks for the information. The prices is as follows:
Cube Stereo 120HPA Pro - R19 940
Silverback Sido 3 - R20 890
Titan Sonic Elite - R20 900
Pictures to follow
The Cube is definitely the best looking bicycle, but the Sido is leading if I look at the comments so far. Below the score and comments according to the replies
Silverback Sido  _  +3 and best suspension
Cube Stereo  _  +1 and best looking
Titan Sonic Elite  _  better drive train
The Silverback Sido !!!! I know they can handle the weight... Mine does. Plus it has a lifetime warranty.
Thanks. yes, I do agree, the lifetime warranty is a big plus.
