Dropper post 27.2
Quagga
Hubbers
Can you maybe help me find this, not sure if it get made.
Dropper post
External Routing Best option (Maybe I can make internal work)
27.2
100mm drop min.
400mm plus (the distance from my Seat rails to top of seat tube is  269mm
20mm min setback
Looked at Lyne.
But their External is straigt only :-(
Hope someone can help
KS Lev have some options - but prices will make your eyes water.
I am assuming that you are already slamming the seat back on it's rails as far as possible? As far as I know Lyne are the only reasonably priced options in the 27.2mm variety...
With a straight post, I will be on the bend of the saddle rail and I dont think it will last long like that . :-(
Looked at Rapide, and they only do 30.6 :-(
had the same problem. Ordered a Brand X dropper from CRC.  Problem solved.
Brand-X Ascend 27.2 CX Dropper
It's only 85mm but it works for me.
I wished they had a 20mm setback as the 0 offset does not work for me
I am going out on a limb here, but is your frame geometry not the root cause that needs to be addressed first?
Sounds like the frame might be too small for you and possibly some of the geometry elements to make it work require you to have a once-in-a-blue-moon seatpost?
I have always been riding setback seatpost since the days of 26ers. Just the way my body is "configured" :-(
Layback droppers are few and far between because of the additional stress on the telescope mechanism from the added bending moment.
Even if you do find one it's unlikely to last long, especially at 27.2.
How long have you had it, and how's it holding up so far?
  • 2 weeks later...
I'm looking into getting a 27.2 dropper for my Epic and everywhere I look Brand-X are being talked about . . .
  • 3 weeks later...
Did you find one? Also looking for my Epic
