Swany05
Im in need of a new set of tires. The current ones are brittle and thin as a ballsack
80/20 road/gravel single track.
Currently riding a 26" hardtail with tubes as im not sure my wheels will handle tubeless all that well
Thanks in advance
if you are riding 80% road, you should look at a tire with a semi slick / less aggressive thread profile. What is the intensity level of the 20% singlet rack you ride?
Also, the "thicker" the tire's sidewalls, the heavier it will be.
Maybe look at Schwalbe's  Rocket Ron/Racing Ralphs with the EVO or snakeskin sidewalls, else you can try Maxxis Agressor up front, with a Maxxis Crossmark at the rear.
You can run Crossmarks front and rear, but I would suggest a grippier tyre up front to prevent washing out.
The crossmarks also ride well on the road and don't wear out as quickly as the schwalbe's.
Schwalbe's Rapid Rob might also be an option, if you can find them in 26"
Yeah the single track wont be technical at all. mostly dirt paths etc.
Thanks in advance
I've been told that friars balsam will sort out that thin ballsack skin of yours.
My word can you imagine that. used once on a blister, never ever again thank you very much
