Hi there,
I am hoping that someone can help me, please.
Two of the bolts on my frame are stripped and can not be turned loose anymore. (Do not ask please) Can anyone point me in a direction of where to buy a new kit.
Thank you kindly.
25 minutes ago, RuanWC said:
Hi there,
Thank you kindly.
How did that happen........... ????
It happens!  As above get direct from Pyga Industries in Pietermaritzburg.  If it is the hex key hole that is stripped as a temporary fix you can remove the bolt with a bolt extractor and then drill and tap the hole to take a small bolt to refit it.
Are you able to take a pic of what you're talking about? I've replaced quite a few items on mine, I might have some spares lying around.
