Going from 142 to 148, no problem with a conversion kit, my one bike got this front and back, work 100%.
Going from 148 to 142, not so easy.
What frame do you have?  If it is rather flexible like my Rapidé, you can try to fit the 148 on a 142 frame and then you don't have to worry about the rotor spacing, it will be correct.
Edited by TheoG
Its the Syncros hub on the new Scott spark with alloy wheelset. The frame is a Cannondale scalpel 2020
OK, I have a m8000 hub body, and a m8010 thru axle. They're not compatible.
I had a problem with my qr hub in the past and the lbs rebuilt the m8010 hub (which is thru axle) to a quick release. I have the remaining hub parts which you're welcome to use to rebuild yours
The thru axle part above is brand new. The hub is my old m8000 32h. The thru axle part does not fit into the hub though
Failing all that, call @Kiwi at Rapide.co.za , I know they do a 32h thru axle hub in 142mm - I have one of theirs now with a 12sp micro spline freebody
DM me if you want to try the hub parts I have. Mahala
You can get adapters from 142 to 148 as long as the hub isn't centrelock, but not 148 to 142. The issue is that the spacing between the cassette and the brake rotor is where the extra 6mm is, and you won't be able to make that up by adjusting RD and caliper spacing.
Rebuild with new hub or find another wheel.
Expand
I found adaptors (non boost to boost) for center-lock hubs, it does however convert to 6 bolt which is no problem for me ... :).
https://www.summitbikes.co.za/index.php?id_product=1406&controller=product&search_query=boost+conversion&results=23
  On 2/7/2023 at 10:48 AM, Me rida my bicycle said:
You could try machining just 2mm off each side the frame will definitely not have a issue with 2mm flex that way it might still work. You are going to need to dish the wheel anyway for the Cannondale if I'm not mistaken.
Expand
I'm riding like this for months now, the flex is not much, the frame can easily take up that flex (depending on the frame).
I didn't remove anything in fact I simply popped a boost wheel into a non-boost frame, and it work 100%.
Expand
I have also done it, a longer axel might be needed. It's 6mm difference which is like a fat spacer but a little bit off won't be a bad thing.
