Hi - I need something to help me follow a Strava route without having to dig out my phone the whole time. I dont want to put the phone on a handlebar mount. So was wondering if the Edge 130 can do this? Thanks!
The 130 doesn't have base maps, as capediver says - but it still gives you a breadcrumb trail which will be fine if you're not going too fast or on technical terrain, since you have to keep your eye on it quite closely.
For something with maps installed and turn-by-turn nav, you'll need a 520 or higher.
Expand
You can download a route onto the 130 and then ride that route. It's not as nice as Strava on a mobile phone though.
Expand
I think it depends on how serious & how often you want to follow Strava routes (and I assume in places that are unfamiliar to you)
If only very occasionally, sure the breadcrumb thing on the 130 will do the basic job for navigation. But if regularly I think the limitations on the 130 will probably outweigh the usefulness and just frustrate you.
Even on devices like the 520/530 with better features the navigation can be temperamental at times. Just this weekend I got a bit lost in the Riviersonderend mountains trying to navigate a private mountain pass on the 530 ðŸ˜ƒ
If you want to navigate regularly, I wouldn't go with anything below the 530.
The 130+ is single handedly the best unit garmin makes for users who do not need maps functions.
having owned a 520, 530 1040 solar and now the 130 Plus.
i love my 130 plus the most - if i ever need maps for a ride i will obviously have to upgrade.
if i needed maps i'd wait for the replacement of the 830 - touch screen is a big benefit
Expand
having used the navigation on the 130,I would not use it for anything other than road cycling. I think once you hit offroad it will just frustrate the heck out of you.
Even on the road its not brilliant. It works, but just.
  On 3/21/2023 at 6:39 AM, Randolph said:
Thanks everyone- very useful feedback. I think I will just poach my wife’s old iPhone and get a bicycle mount
Expand
The 130 is mostly fine for mountain and good enough for roads. If you're on the mountain and there's a fork on the trails it won't really tell you which split to take.
An older phone with Strava might work better for your use case.
Expand
How's the screen compared to edge 500. My 500 getting old now. So starting to look at replacement. I just use the basic stuff like hr, speed, cadence, elevation, grade etc
Expand
500 and 705 are the original workhorse models.
They did everything required and a bit more.
Managed to get the battery on my 705 replaced which gave it a new lease on life ... so much so that the 130 is still sealed in its box. ðŸ™ˆ
Expand
They are better.
side by side there is a difference.
 If your battery is still getting you through your rides then the screen is not a big issue.
 For me the addition of crash detection, live tracking and radar compatibility are big bonuses
